Help w/ JD Sabre S1642
   / Help w/ JD Sabre S1642 #11
i was wondering if the engine had been changed. if you get the model and type number off of the engine you can go to ordertree.com and look up part numbers for the engine. for that reason when i need parts for any equipment that i repair for the customer i always order parts for the part of the equipment that I am working on. for example a poulan pro rider, if i file a warranty claim the engine is warrantied through the engine manufacturer, the transmission is warrantied through the transmission manufacturer, and the rest if through poulan. that is three different possible manufacturer claims one lawnmower.
RandyT-Thanks again for the info, and the link to ordertree.
   / Help w/ JD Sabre S1642 #13
If it has the briggs engine do the valve adjustment first. 9 times out of ten that will fix it along as the starter hasn't been destroyed in the process.
I have a feeling that the valve adjustment may be over my head. But out of curiousity, how do you do it?
   / Help w/ JD Sabre S1642 #15
usually if the valves on the engine are out of adjustment it will try to turn the engine but will kick back the flywheel when it fires. the valve adjustments are .004 for intake which is the bottom valve and .004-.006 for the exhaust. loosen the lock nuts on the rocker studs which is 10mm and then back off the torks screw in the lock nut and adjust the valve clearance with the lock nut and then tighten the torks screw to lock it down but i think the torque on the screw is 100 in/lb (not 100% sure)do not exceed or it will crack the lock nut.
Ok, I got the starter on, but now have a new problem. The starter will spin the engine 1 time, but that's it. I replaced the plug, but am 90% sure that the problem is that it's flooding. I can actually hear the fuel pumping when I try to crank it. After a minute or 2 the starter will try again, guess that is after it drains back out.
How hard is it to rebuild the carb? About how much would it cost to have it done at a shop?
As always, any advice is appreciated.
   / Help w/ JD Sabre S1642 #17
I think it''s time to sit down and think about what's happening here. You don't seem to have a handle on what the problem symptoms are. You can swap parts for a very long time without fixing your problem.
With the spark plug removed does the starter spin the motor at a high rate? Have you checked the compression? The carb needle should shut off the fuel when the bowl is full, regardless of the sound of pumping. The folks that told you about valve adjustments on Briggs OHV engines weren't kidding; when the valves are out the motor bites on the starter, and in a pull-start it will peel the hide off your fingers.
I guess what I'm saying is that you have to identify the problem before swapping parts or getting the carb rebuilt. If it isn't clear to you it might be cheaper to go to a repair shop and have them identify the problem.
I hadn't gotten back to this. Old starter was junked. After putting the new one on, I am 99% certain that the carb is the new problem. Pulled the plug and gas poured out. I have a call into a shop, he said he'd take a look at it and see.
Looked online at rebuilding the carb, didn't look too hard, but I chickened out.
Anything else to check, or try before I haul it in. I may decide to check the carb float, but it would be a first for me.
Put this project on hold, as I bought two other projects. A small rear engine that I'll refurb for my dad. Great deal, replaced a pully, jumped it off and it mowed the yard. I'll "test" it a few more times before I pass it on.
Also got a Cub 1330, deck is shot, may rebuild it, but may become another project. I have a post on that in the Build it Yourself Forum.
Thanks for all of the advice, I love the forum.
Ok guys, guess I should have listened to y'all earlier on the valve advice. At least I didn't bother w/ the carb. I messed w/ it today, set the valves, and it fired right up. Of course, as with most things I do, once I shut it down, it wouldn't start up again. Still the same, hanging up. Guess I am at a loss, it will go into the shop this week, unless there is any other advice.
Oh, to answer the questions earlier, spins great w/ no plug in.
Ok, so I have to say it again. The valves were the problem. I had it checked out, the mechanic said the valves were good after I fixed them.
Problem with it not wanting to start the 2nd. time was a bad battery. It would show charged on my charger, but wasn't really. Mechanic hooked it to a big charger and it took right off.
Got to mow last night, and it was great. Thanks again.
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2015 F-550 Bucket Truck. (A53472)
2015 F-550 Bucket...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
