help with 110tlb
/ help with 110tlb #1
jcw9500
Kingston, Ok
110tlb
I need to take injectors out. they are stuck going to make slide hammer. tractor is 80 miles away.
Does anyone know what the thread size is on top of the injector?
thanks
/ help with 110tlb #2
Maybe I'm not understanding you, but the injectors are threaded in. A slide hammer will damage the injectors threads and the block threads. I don't believe that J.D. press fits the injectors. Take a look at the injectors and you will see flats for a wrench to fit on, left to loosen. Good luck on your repair! If I am way off base then ignore this post.
/ help with 110tlb #3
Why do they need to be removed? Most are threaded into the head; use some penetrating oil prior to removal, and use compressed air to remove any junk that might get in the hole during removal/reinstall.
2021 Chevrolet Equinox SUV (A61574)
2021 Chevrolet...
(2) 9.5-24 TIRES W/ 8 LUG RIMS (A64280)
(2) 9.5-24 TIRES...
COMBINATION ELETRICAL & COOLING SYSTEM (A64281)
COMBINATION...
2020 John Deere HPX615E Gator 4x4 Diesel Utility Cart (A61572)
2020 John Deere...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2715SSFL (A61567)
2715SSFL (A61567)
