FL_Cracker
Platinum Member
- Joined
- Nov 21, 2004
- Messages
- 626
- Tractor
- Kubota L5030HST,R4 & Kubota RTV900R Utility Vehicle
I’m really getting close to the d-day on a new tractor. Here’s the problem, which tractor?
I want a Kubota Grand L, HST with a front loader. I have 52 acres with quite a bit of gravel road and about 7-8 acres of pasture. I will be cutting the pasture with a bush hog for now and need to box blade the gravel roads several times per year. I’m still clearing some areas of the property and clearing debris. I will have a third set of hydraulics added to the loader so I can use an existing grapple I have from my skid steer loader.
One issue is the capacity of the front loader. The rating at the center of the bucket on the LA853 model is about 1800 lbs. Will I be able to get a 1 ton pallet of fertilizer off my trailer or is the 1800 lb. rating the drop dead max it can lift?
I leaning toward the L5030 because I want plenty of power and I intend to rent a over seeder this summer and next summer and it requires 50 hp. I also have a 6” chipper with power feed and I think it will require a lot of HP
Is the backhoe worth buying for general farm use or do you find it ends up sitting doing nothing most of the time?
Cab and Air looks and feels great but I wonder if it has problems with every day use. I don’t need the cab from harsh weather as north Georgia doesn’t get much snow. Any body with can & air experience.
Boy, that’s a lot to ask but it’s a big number to just jump….. without getting some opinions.
Thanks,
Thanks,
