Help with phone problem
   / Help with phone problem #41
<font color="blue"> Think it may be time to call in the Calvary </font>
Er, um, did you mean Cavalry? /forums/images/graemlins/grin.gif /forums/images/graemlins/blush.gif
   / Help with phone problem #42
/forums/images/graemlins/laugh.gifWhere you put that "l" does make a difference, doesn't it? /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif
   / Help with phone problem #43
You sure do not need a transformer for basic analog telephone service. Make things easy on yourself. Unhook all the jacks in the house. On the demarc outside hook up red to red and green to green. Go inside to the first block and hook the red and green to your jack. Check to see if everything works OK. If it does then proceed to the next jack. It's not exactly jet rocket stuff, just 2 wires.
Just remember, if you look at a phone jack the red and green wires are the 2 center conductors and are used for line 1. The yellow/black wires go on each side of the red/green and are used for line 2.
In the days of Princess phones people seldom used a second line so telephone guys used the yellow black for the power to light the dial.
Now, here is another thing to remember. Someone mentioned previously they had some old ATT/Bell touch tone phones around because they were so reliable. They are. They are the best corded phones made and were all made at Western Electric (another Bell System Company at the time) in Indianapolis Indiana. However, if you hook one of these up and cannot break dial tone just connnect the red to green and green to red at the jack. These babies were polarity sensitive.
Now, if your color code is blue, orange, green, brown, slate.
then you have 5 more wires with blue/white, orange/white, green/white etc....
Use solid Blue for the Red (or Tip) and Blue/White for the Green (or ring). Then orange and orange/white could be used for line 2 or in place of yellow and black .
Geez,, can't believe I got that involved.
Good Luck.
Tom
   / Help with phone problem #44
At that common point in the basement, you can disconnect all of the wires (isolate each individual station wire going to a jack) and use a ohmmeter to see if there is a short/near short between the red/green in each individual wire going to the jacks.
With no phones plugged in, there should be no connection between the red/green pair. If there is, that station wire will read different than the others. leave that one disconnected and connect the others and see if the problem resolves itself.
The feed pair coming from the Network Interface Device outside should be red/green for line 1. Don't test this with the ohmmeter unless the test jack jumper in the NID is disconnected. Also, test the red to ground and green to ground. I have run into a grounded red or green that caused the same type of problem.
Do you have an alarm system that is tied into the phones? if so, that can cause that type of problem.
Doug
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
Brock 5 Ton Feed/Grain Tank (A55218)
Brock 5 Ton...
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
2015 TAKEUCHI TL10 SKID STEER (A52705)
2015 TAKEUCHI TL10...
MISC WRENCHES AND SOCKETS (A53843)
MISC WRENCHES AND...
2007 KUBOTA M9540 TRACTOR (A53843)
2007 KUBOTA M9540...
