HELP with rear finish mower
   / HELP with rear finish mower
I've tried a local dealer. Same as Messicks. Part is listed but not available. Thanks
   / HELP with rear finish mower #12
Go online to McMaster.com. They have a large selection of left hand thread bolts. You will still be trail and error, but an educated guess on your end will narrow down the solution. Their bolts are much cheaper than $8 each, but you may have to buy a minumum quantity of 10. My finish mower takes two bolts per blade, as opposed to one bolt in the center. Dont know about yours, but is one solution drilling out the threads, installing grade 8 bolts, washers, and lock nuts? Philip.
   / HELP with rear finish mower #13
You shold be able to look and see if its a course thread or fine thread. My guess would be fine. tape the diameter and see if you can find a standard LH and try it. 1/2"X 2" X LH would be my guess. If it starts but just won't thread past a couple of turns, you probably have a metric thread (unless you missed on course/standard pitch)
   / HELP with rear finish mower #14
Is the gearbox tag in good enough condition to examine it and read it?.
I would hate to suggest the following but if you cannot find left ahnd threaded bolts for the unit you may be better off buying new arbors and bearing hubs for the mower as they are easy to obtain from many places.
You may just luck out and find everything you need at Agri Supply - Farm Supplies, Tools, Lawn Mower Blades, Cast Iron Cookware
1800-345-0169 they have lots of mower spares
saying that and making sure I did not brush my teeth with gun powder this morning-
1. as you know the threads are left handed;
a.be sure to wash out all the holes with WD-40 or alcohol to clean them.
b. use a new unsharpened pencil to determine the depth of the bolt hole-
dont hesistate to scrape around the bottom to dislodge any rust or cob
webs.
be sure to mark the depth on the pencil in the blind hole with a pencil or pen or scratch awl. where the pencil clears the arbor.
If it were me and was limited on tools and such I would find a machine shop bribe with ample donuts and coffee to ask for a minutes help as you are in a bind (if Agris upply cannot help you-but i would ring them up first.
Please understand that if you require a "compression washer" spring to
hold the bolt in place you will need to add length to the measurement of
the bolt and each time the blades come off you may need new washers-again agrisupply can probably be of help
these bolts are left hand thread to counter the G forces of the rotation
and in the process keeping the blades tight
c. are you sure you do not require a "compression washer" to gain more
pressure against the blade as is done with some mowers?
Thanks all for the various info. Decision is to drill and retap to something common. There is enough meat on the spindle and hopefully with lock washer, will be able to keep blades tight. This is not my main mower so it will only be used a couple times a year on about 1/2 acre.
   / HELP with rear finish mower #16
General practice for tapping holes: material (if steel) to tap should be same thickness or greater than diameter of bolt (aluminum is 1.5 X). Example, If using 1/2" bolt, material (if steel) should be 1/2" thick or greater. I am sure you hub is steel or cast iron. If material is not thick enough, consider the lock nut option if you have clearance on the back side. Newer Woods mowers use two grade 8 bolts and lock nuts to secure the blades to the hubs. Philip.
   / HELP with rear finish mower #17
I have that mower and the thread is a 3/8-16 unc LH for left hand if you put some thread locker on the threads that should help from losing a blade I am looking for the knife holder and possibly the entire shaft assembly as one i have is bent and missing parts
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
Sundowner Rancher Express 20FT Livestock Trailer (A55314)
Sundowner Rancher...
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
2020 Autocar ACX Xpeditor Garbage Truck (A55852)
2020 Autocar ACX...
1999 INTERNATIONAL 4700 24FT BOX TRUCK (A56138)
1999 INTERNATIONAL...
44029 (A51692)
44029 (A51692)
