Help with sticking float on Ford 600 series
   / Help with sticking float on Ford 600 series #1
Victor23
Central Florida
Ford 600
My 600 has a float that sticks way too often. If the tractor sits the gas will pool in the air intake. Any suggestions?
I may just have to do a carb rebuild. It has one of the old Marvel carbs.
Thanks.
   / Help with sticking float on Ford 600 series #2
It's probably just some crud betwixt the needle and seat... but.. you should be turning the fuel valve off for safety anyway.
Go ahead and flip for the 'small' rebuild kit ( no float ).. and a can of carb cleaner... If that is the only probelm, you should be good to go.. A toothpick polishes the float set nicely.
I like the marvel carbs a whole lot better than the zenith.
check to see if the sediment bowl needs to be serviced..
Soundguy
2010 KMC 3376 Peanut Combine (A53473)
2010 KMC 3376...
1995 HESSE CORPORATION BEVERAGE TRAILER (A53843)
1995 HESSE...
Flat Bed (A52377)
Flat Bed (A52377)
2013 PETERBILT 388 DAYCAB BOBTAIL VACUUM TRUCK (A53843)
2013 PETERBILT 388...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
