Help with top link adjustment for rotary cutter.
   / Help with top link adjustment for rotary cutter. #161
All you need to completely float a deck is three points of ground contact. Heck, you could drag it from the hitch if you had front gauge wheels. What you will have is a rough cut finish mower.
I think part of the character of a brush hog cut field is the slight variations. Digging in to the dirt should really be avoided though.
   / Help with top link adjustment for rotary cutter. #162
   / Help with top link adjustment for rotary cutter. #163
My situation is the opposite of Beenthere's pic. I have a ditch bank I'd like to keep free of multiflora, but the ditch is alongside a 60 mph road and near a blind corner. If I can figure out a way to lower the mower from the top so it will cut at about a 45 degree down angle from a level tractor, I'd be sitting pretty. I may need to get a new PTO shaft, but do you guys have any ideas about how to rig things to allow the mower to hang down over an edge for mowing yet still be able to pick it up to at least level to move over 4 feet and do it again? No, I don't have T n T, but I do have a set of rear remotes.
   / Help with top link adjustment for rotary cutter. #164
   / Help with top link adjustment for rotary cutter. #165
</font><font color="blue" class="small">( I may need to get a new PTO shaft, but do you guys have any ideas about how to rig things to allow the mower to hang down over an edge for mowing yet still be able to pick it up to at least level to move over 4 feet and do it again? )</font>
I've have set mine, at times, to allow the rear to hang way down by lengthening the top link to the extreme. I was still able to pick it up enough, with the tailwheel still touching, to move over and back into the material. I nearly never have had to pick it up all the way, just enough to let it move.
I back into my ditches with the mower up some, and as it goes in, I start lowering it to cut. Works great for me.
John
   / Help with top link adjustment for rotary cutter. #166
John
   / Help with top link adjustment for rotary cutter. #167
<font color="blue"> You've got a crazy twist on your belt. </font>
Highbeam,
That is common for that era Woods RFM. I have a RM59. It is a tank, but what really gets twisted is your brain as you try to put that belt on! /forums/images/graemlins/confused.gif
Gary
   / Help with top link adjustment for rotary cutter. #168
Highbeam,
Gary
   / Help with top link adjustment for rotary cutter. #169
djradz
In your pic posted, its a good one of the check chains for height, but I don't see any allowance or room for the rear of the deck to raise without bending something with that top link being so long.
A good place for a chain instead of the toplink. /forums/images/graemlins/wink.gif
   / Help with top link adjustment for rotary cutter. #170
djradz
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
Landoll (A50657)
Landoll (A50657)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 Cadillac Escalade ESV Platinum AWD SUV (A50324)
2015 Cadillac...
Loader with IH Brackets (A50515)
Loader with IH...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
