Help with which Kubota to get
   / Help with which Kubota to get #21
You'll regret buying too large just as much as too little. Bigger is better - not. Buy what you need.
   / Help with which Kubota to get #22
Beautiful area out there! Definitely looking at a quick attach loader and I'm now leaning towards the MX 5400 (54 hp) after some of these suggestions. I like the idea of wider wheel base and more weight as our property has some pretty unever terrain. Is your place very hilly? If so, how is it operating the tractor around some of the steeper parts?
I would love to have some blackbuck - unfortunately our place isn't high fenced. Add it to the wish list!
blackbuck antelope like wide open spaces, our fences are 4 foot and 5 foot high. They hate to jump fences. We have about 20 acres open pasture and 10 which is maybe 50% trees.
Our terrain is mainly gentile hills but I have a steep area that I'm careful when working. I think the MX 5400 would be a fine choice for you.
   / Help with which Kubota to get #23
Get a tractor big enough to move your bales of hay. AG tractors are more like all in one tools made to do a little of everything but not exceedingly well at any one thing.
Clearing pastures and removing stumps is hard work, Id suggest getting on older used construction TLB, let it take the abuse and sell it when you are done likely for the same amount of money you paid for it.
Keep the tractor for long term, add on front remotes to operate a grapple and rear remotes for utility.
Good points
What size of hay bales will the OP be buying and moving?
he mentions rounds in the 1st post.
We switched to large squares a few years ago, (~1275lb) and it sure saves time and labor when getting the years supply of hay in.
2 people can move and stack in a couple hours, what took several people several hours when small squares were delivered and then stacked.
If the OP wants to use large bales- this is an area where a smaller tractor cannot get the job done- by just taking more time.
If it will not lift the bale, it will not lift the bale...
Rounds (depending on size) Range in weight quite a bit
To quote Jeff, " Buy Enough Tractor" so those round bales can be safely moved and stacked.
Good points
Right now we just have small square bales as we only have two goats. Soon we'll have more goats and a couple of horses so I suspect we'll step up to larger bales. I really don't know if we'll ever need large round bales or just larger square bales
learn something new... I just always assumed you needed high fences for them. Our neighbor has a zebra so I imagine that would deter them even more from hopping their fence.
I appreciate your help!
   / Help with which Kubota to get #26
I am going to add my opinion here as well.
I believe after just getting my new tractor delivered a week ago, that there IS a thin line between buying too big or too small. It is hard to decide which tractor is the right size.
I started out looking at an L 33 hp. Once I found out how much the FEL would lift, I switched to a 39hp. I quickly went from that to looking at a 47hp L series.
I had pretty well decided on the 47 hp tractor, until one dealer suggested that I should move from that decision on the 47hp to the MX5400. He said for the 2k$ difference it is a no brainer.
But it may be a "brainer". IT is a bigger tractor, more weight if YOU need more weight, but more weight if you do not need it too. Wider. May be a problem for storage. Longer, may be a problem for storage. The bigger tractors will consume more fuel. I used a lot of fuel for just 8.5 hrs of use. The tank was full when they brought the tractor and I just refilled it with 5 gals.
I cannot complain about how much my loader will lift. I used my grading scraper to grade my gravel driveway and I did have to use the front wheel drive to keep moving, but after I put it in, zero problems.
Hope this helps a little.
   / Help with which Kubota to get #27
[Not disagreeing with aquabird, just adding my 2 cents]
It all comes back to identifying the problems you need to solve. I started looking at the L3901, and in the end also migrated to the MX5400, but for me it has been the perfect decision. I wanted the weight, and especially the stability from the additional 20% tractor width compared to the L3901. But one of the problems I needed to solve was my very hilly and uneven terrain, so stability was important. As was weight for potentially skidding and other operations (even if I wasn't trying to solve that problem right away).
As for storage, that's like a whole separate dimension in planning. Even if you ignore individual tractor and attachment dimensions, if you have a few attachments and want to keep them out of the rain and snow, then storage is really a challenge! (Or can be unless you're blessed with some gigantic shed). Definitely think about what you will want to store indoors and where you will store it. (For me, that's all PTO engaged implements, all things with hydraulics, and in general all things I can manage to keep them from rusting. But I like to keep my toys shiny and looking new.
Also to consider, how you'll haul the beast. I had to basically write off my current vehicle as unable to haul the tractor. While I could probably haul it with no attachments, there's no way I can haul the nearly 4 tons of tractor (when you include 2 implements & loaded tires) with the 9K towing capacity of my truck. So ... another problem to solve.
   / Help with which Kubota to get #28
On Aquabird's size considerations, there are definitely people who've voiced preference for a smaller tractor if you're doing things in the woods, for better maneuverability. Though for me that's been less of an issue than all the gigantic stumps left by loggers that I'm afraid to drive over, even with the nice clearance of the MX5400.
   / Help with which Kubota to get #29
I do agree BW, You definitely have to consider the job you need to get done and the terrain you are working in. I would say 60% of my tractor work is mowing 3.5 acres. I live in a really flat area. I do not intend to load the tires up. I did some loader work today and was really impressed with the power of the loader on the MX5400. Does yours gulp fuel?
I am also very impressed with the traction of the 4 wd. I guess that the weight of the tractor has something to do with that. I am sure that when I put the big rototiller on I will be glad and I have that extra PTO HP.
   / Help with which Kubota to get #30
Hey Everyone - brand new to the forum after doing some research into tractors. My wife and I recently purchased a 15 acre spot in the Texas hill country and we're looking for our first ever tractor. I've done quite a bit of research and am leaning towards a Kubota (we have a couple of dealers in the area that seem pretty good). However, I'm having a real tough time figuring out what size tractor we need. We have a small nubian goat herd that will grow to 15-20 or so and then we plan on getting a couple of horses as well (would love a couple of longhorns but that probably won't happen any time soon). Most of our chores will be bush hogging some open areas and under our larger oak trees, pulling out cedar stumps, and mainting our gravel driveway. I think the L series Kubota should be able to handle almost everything we need outside of possibly needing to move round bales in the future. Anyways, would love some insight from you guys or if there are resources handy that you could point me to that would be great as well. Thanks!
Don't have a lot else to offer, but we just purchased an L3301. The loader w/ SSQA and a hay spear handles our 5x5 round bales (alfalfa mix, Alpine, LaMancha, Nigerian, and Sanaans) with ease. I am usually moving them without anything on the rear because of being in tight quarters. When I move the one last night I did have to put it into 4wd because I have a board at the sliding door for it to seal against and I had wedged the front tire against it and it wanted to spin. Locked it in 4wd and placed the bale right where I wanted it.
2016 PETERBILT 579 DAYCAB (A53843)
2016 PETERBILT 579...
10' FIELD CULTIVATOR W/ ROLLING BASKETS (A54756)
10' FIELD...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A52706)
UNUSED CFG...
2015 Ford Explorer AWD SUV (A55758)
2015 Ford Explorer...
2015 Ford F-550 4x4 ETI 37ft Bucket Truck (A55788)
2015 Ford F-550...
2015 New Holland TS6.130 4WD 130HP Agricultural Tractor with Alamo Slope Mower (A55787)
2015 New Holland...
