Here is a Implement you don't see everyday
   / Here is a Implement you don't see everyday
Sold the Landpride straw crimper today. Ken Sweet
   / Here is a Implement you don't see everyday #12
Did you ever throw down some grass seed, then cover that with straw, just to see the wind blow the straw away after you walk away....? Straw crimper "crimps" the straw into the soil just a tick so it stays where you put it. That lets the mulch straw do what it's supposed to do. (ie prevent erosion, protect seed, preserve moisture)
OK, makes sense...Thanks for the explanation. :thumbsup:
   / Here is a Implement you don't see everyday #14
Looks darned similar to a coulter cart to turn a drill into a notill drill!
   / Here is a Implement you don't see everyday #16
I was looking at the pictures of that crimper. I have never seen one.
Ken, FWJ...Why can't you use your disk? Throw the straw out, then straighten your disk gangs and lower lightly? Just wondering...
   / Here is a Implement you don't see everyday #17
Some folks do it that way. Straw crimper works better with straight coulters....Plus, the way the crimper is made, it's easier to put weights on it in the event you need additional weight.
   / Here is a Implement you don't see everyday #20
I was at the scrap yard and found part of a bermuda crimper with 1/2 inch wide coulters. They are on 2 shafts so they touch a bit and a flat drum roller on the back. We are gonna use it to crimp straw at the landfill. I just got my motor back for the old Finn blower.
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 Horizon Trailer (A55973)
2022 Horizon...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
2020 SAVANA 3500 16FT BOX TRUCK (A59575)
2020 SAVANA 3500...
