Hey guys!
   / Hey guys! #11
She looks good, thank goodness she has power steering with those big fronts.
As for age, she should be late 58 thru mid 62, assuming she was diesel from the factory, and is wearing the correct tins. The bellhousing flat aft of the starter will show model # and sn, we can date her exactly from there.
Those are great machines. I prefer the 9xx rowcrops, especially nartowfront models.
If she runs like she looks, keep her serviced and you should get years out of her.
Remember, as a diesel, she is 12v neg ground.
Looks like she even has a generator instead of ugly alternator.
   / Hey guys!
Thanks for the info soundguy. Could you please explain the 2 stage clutch to me? Also is this going to require cat 2 implements? TIA
   / Hey guys! #13
she will use cat 1 implements.
On the 2 stage clutch, say you have the pto engaged and you are mowing. If you press the clutch half way down, she will stop moving, but the pto will still be engaged. if you press it all the way down, the pto stops as well.
If it was a single stage clutch, you press it all the way down, and she stops moving and the pto stops.
72'' root grapple (A53421)
72'' root grapple...
2013 KENWORTH T800 KILL TRUCK (A53843)
2013 KENWORTH T800...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2002 Enclosed Trailer (A52377)
2002 Enclosed...
2013 KENWORTH T800(INOPERABLE) (A53843)
2013 KENWORTH...
