HF 3/4" socket set
   / HF 3/4" socket set #1
kossetx
Platinum Member
TX
NH TC 40 A, AC 5020
Anyone ever use a HF 3/4" socket set? I don't need anything that big very often, usually only with the bolts on a shreader. With 15% off it is only 34.00, but will it last past the first heavy use?
   / HF 3/4" socket set #2
Got one in SAE and one in metric; no complaints. I do NOT expect them to be snap-on quality or tough. I recently used it to remove my bushhog blades. Put a 7ft long piece of pipe on the breaker bar/extension/socket and both wife and I pulled for about all we were worth. I fully expected something to break. First nut came off fine, second one broke the socket end of the extension. Used the shorter extension and it came off OK. I figure the local store will replace the extension for me once I get time to get back there.
   / HF 3/4" socket set #3
I think the set is fine but it didn't have a 1 11/16" that I needed for my BH blades. 1 3/4 probably ok but I passed at $50. Probably not have passed with your coupon. :)
   / HF 3/4" socket set #4
I haven't bought it, but I asked about it not long ago and several people said they use it and have no complaints. I, too, wouldn't need a set that big very often but at $34, I'd buy it.
   / HF 3/4" socket set #5
I tried to use the 1 1/4" socket from the 3/4" Harbor Freight set to remove the tail wheels from a Ferguson hay rake but the socket slipped on the nut. I switched over to a 1 1/4" socket from a 1/2" Harbor Freight impact set and the nut came off. I was only using about a 12" bar.
   / HF 3/4" socket set #6
I have a hf sae / metric set.. I've had a 4' cheater pipe ont he breaker bar.. I ran out of arm long before they even got well worked over. I simply can't imagine breaking the bar or a socket with my puny arms.
soundguy
   / HF 3/4" socket set #7
Don't plan on the racthet lasting very long. After 10 uses mine now slips.
   / HF 3/4" socket set #8
Oh, oh, get this, I have a set from there that is clearly stamped "China", but I haven't been able to break any by hand. :) I bought a 3/4 set and 1" set from HF back when I had a dozer and a backhoe. I'm a fairly stout guy and can rather easily break 1/2" tools by hand if I don't watch it. However, it must take a real animal to break a 3/4" socket or ratchet. I don't use any cheater bar. If I do, I'm sure I'd be asking for trouble. I still have a Craftsman 1/2" ratchet with the 1/2" nub part broken right off at the head from when I used it to try to take some lug nuts off of an old VW Karmann Ghia I had. Using a good 6 pt. impact socket with the Craftsman ratchet I was actually picking the rear wheel of the Ghia off the ground trying to break the bolts loose that were on the wheel.
So, in all fairness, I have to admit that I am pleased with the 3/4" and 1" sockets and ratchets I bought there. If I had to use them every day for a living, I may buy more expensive and better ones, but for my needs they work fine.
Dang that hurts; twice in one week I talk about being satisfied with something from HF....:eek:
*edit*
I have used a cheater bar in the past. I was using a 2" breaker bar that was about 4' long to try to take off a 6" nut. It wasn't happening. I used a 6' cheater bar and two other guys to break them loose. Ever seen a 6" nut? I can post a pic of one. I kept one that came off that dragline. I use it as an anvil when I don't want to chance breaking my Peter Wright anvil.
   / HF 3/4" socket set #9
You better be careful...or you may find yourself in HF to buy some chains:D
   / HF 3/4" socket set #10
Ouch! Man, that is a low blow! :eek: I'd better crawl off and hide before you guys get me on their mailing list... :eek:
1978 ASPT 30ft Pole S/A Towable Trailer (A48081)
1978 ASPT 30ft...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2023 Ford Explorer SUV (A48082)
2023 Ford Explorer...
2011 Chevrolet Impala Sedan (A48082)
2011 Chevrolet...
20 ft. Shipping Container (A50860)
20 ft. Shipping...
Industrias America 10F Pull Type 10ft. Box Blade (A50860)
Industrias America...
