HI- LIFT JACK PROBLEM
   / HI- LIFT JACK PROBLEM #1
Aussiebushman
Jerrong, south of Oberon in NSW, Australia
Ford 6000
I searched the forums but can't find anything on this subject - apologies if I missed something.
My H-Lift jack is a wonderful tool and has got me out of a lot of trouble, but recently, the lever SLIPS from the "up" position to the "down" position without warning. It is obviously difficult to hold the lever in place while jacking and potentially bloody dangerous
I have examined the pins etc and can't find anything obviously wrong. Any suggestions and links to repair information most appreciated
Alan
   / HI- LIFT JACK PROBLEM #2
Hmmmm - - from your pics, I can see nothing wrong. My Hi-Lift is probably a lot older than yours - wooden handle & not the fancy shift lever - purchased in '67. I would suggest going to the Hi-Lift web site and accessing the Instruction Manual. Scroll down to the parts page with the exploded view of the jack. There is part # 13 - reversing switch spring. I would suggest that yours is either all gummed up or bent/missing/broken. Start by spraying this entire area with something like WD40 and "work" the mechanism. This - very likely - will loosen & lube things and you will be back in business. Otherwise, you may have to replace either this spring or a bent part, such as, #14 - reversing switch cam bar. I've torn mine down several times to clean & lube and with the exploded parts picture its not difficult to reassemble.
   / HI- LIFT JACK PROBLEM #3
I purchased a tune up kit for my jack at Tractor Supply. Works like new now.
   / HI- LIFT JACK PROBLEM #4
The weight of that homebrew handlebar extension for the switch might not be helping.
   / HI- LIFT JACK PROBLEM #5
If you raise the handle too high, it will automatically kick the lever into down position. I suspect that is what you are doing.
Thanks guys - good advice
Don't think I'm raising the handle too high but I'll watch out for that. Part # 13 - reversing switch spring could be the problem - I'll check it out and yes, I could have bent a bar by overloading
Thanks again
Alan
   / HI- LIFT JACK PROBLEM #7
Your jack has less of a notch than I usually see.
Photo from jack rebuild page here:
Hi-Lift Jack Rebuild
Bruce
   / HI- LIFT JACK PROBLEM #8
Hi Aussiebushman,
+2 on what oosik posted. I have found in the past that a good flush with WD40 works great.
Cheers
I've cleaned out any remaining crud with degreaser and used Rostof as a lubricant (better than WD40 by far), but I think Bruce has hit on the cause of the problem. This is a Chinese knockoff - not a Hi-Lift original and as usual, they never get it quite right. Looking at mine again, it is really not a notch at all - just a curved indentation so it is no wonder it slips.
My first thought is to take an angle grinder to it but on reflection, maybe adding some weld and reshaping the notch to make it deeper might be even better
Thanks again
Alan
377965 (A48837)
377965 (A48837)
1997 John Deere 8100 MFWD Tractor (A50397)
1997 John Deere...
2007 Ford F550 Flatbed (A50397)
2007 Ford F550...
2021 CATERPILLAR 259D3 SKID STEER (A50458)
2021 CATERPILLAR...
2012 Chevrolet Tahoe 4x4 SUV (A48082)
2012 Chevrolet...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A50397)
2018 Rock Solid...
