high level intro to brake controllers?
   / high level intro to brake controllers? #1
MattEffinCameron
New England
B2920
so I have a 2007 F150 with tow package and just bought a kubota b-series. I have been looking at buying a 16-18' dual axle trailer to transport the tractor with and my brother also owns an 18' dual axle (7000gvw i believe) trailer that I could borrow.
According to my research, I just need to pick up a brake controller, which will plug into a connector under the dash, put a relay into the fuse box, and I am ready to tow? Does this mean I could also easily swap the controller out in a matter of minutes to my dad's or my friend's 2006 F150s to do the same? Do I have to do anything on the trailer?
Do I need to bother permanently mounting it or can I just connect the wires and stick it under the dash for a brief haul if im going to be using it infrequently? I have seen mention of supporting 360 degree vertical rotation (specifically with the prodigy P2) but I am guessing that means it can be mounted at any angle, but it probably does need to be put in a fixed mount so it can properly calculate braking needs etc..
   / high level intro to brake controllers? #2
You say your truck has a 'tow package', not sure what that includes. Does it have trailer plugs at the rear? For trailer brakes, it should have a 7-pin round receptacle.
Brake controllers need to be solidly mounted in the tow vehicle. As you mentioned, most have sensors that let it determine how much braking effort is needed as you stop the vehicle.
   / high level intro to brake controllers? #3
That Prodigy P2 should work in both trucks if they are wired for it (tow package), as I understand it. I don't think that a relay is even needed, IIRC. You may need to add a fuse in the box under the hood, IIRC. But heck, I'm an amateur. Others on TBN are more savvy than I. The trailer connectors probably will work as is. IIRC, the P2 can be moved by just disconnecting it under your dash. Also, the e-trailer company can help with advice ( as just one example).
I'm assuming that all trailers have electric brakes, not surge brakes, in which case no controller is needed.
cool, thanks.
All the trucks with tow packages (this generation ford anywya) have the round 7 pin receptacle. There is other stuff included with the tow package obviously but with relation to brake controllers i *think* it means i have the round plug at the back to work with trailer brakes and the truck is wired for trailer brakes, just missing the controller....
   / high level intro to brake controllers? #5
You are correct, you can just move the controller around if needed. On the Fords the Relay is needed as is a fuse sometimes. It no more than a 15 minute install.
The relay is used for power to charge the brake away battery on the trailer. The fuse if needed is to supply power to the controller itself.
Chris
   / high level intro to brake controllers? #6
Chris
With a Ford, I go with a factory controller and have the truck computer reflashed. You usually mention this as the best way to go with a Ford, Chris.
   / high level intro to brake controllers? #7
Not available on that year F150. Super Duty only. F150 did not get the factory controller till 2011 I believe. Super Duty got it in 2005.
You are right though, it's by far the best option
Chris
   / high level intro to brake controllers? #8
Chris
I had so many F150's from 1986 to 2013 model years until I bought a 250 last year that I can't remember which years had it and which didn't.
   / high level intro to brake controllers? #9
The ONLY brake controller I like is one that ratios the trailer effort off the towing vehicle's brake system pressure. Unfortunately, these models are expensive and hard to find, if you can at all. On the plus side, you ALWAYS get exactly the braking effort needed by the trailer once it is set up correctly initially, no more braking and no less than needed - always.
Every other non-OEM solution uses either an operator input or some form of inertia measurement to guestimate at the correct trailer braking effort, which is almost always WRONG.
so I got a prodigy P3...I dont plan on using it often...and I am a big guy so theres not a lot of mounting locations that are out of the way that my knee wont smash into (I have the captains chairs in the front so I dont have that space under the dash in the middle).
Any thoughts about putting it under the driver's seat?
There is a raised flat surface under the front center of the driver's seat. I could velcro it right there for easy install/removal but that might not be a fixed enough position for it to work as well as it needs to...so I could always drill in and mount it there. Issue would be that the controller would either be facing backwards or facing the correct direction but I wouldnt be able to see the front of it as the front of the unit would be facing the area under the seat....
2022 John Deere 5075E MFWD Tractor (A53485)
2022 John Deere...
Kubota BX2230D (A47384)
Kubota BX2230D...
2016 Peterbilt 597 Wet Kit Tri-Axle Day Cab Truck Tractor (A55852)
2016 Peterbilt 597...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2004 Caterpillar 345B Hydraulic Excavator (A53421)
2004 Caterpillar...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
