Hit stump now one blade is not turning
   / Hit stump now one blade is not turning #1
beltondorf
Tyler, TX
Kubota MX4700
I have a Land Pride RCR2596 rotary cutter and I hit a tree stump while mowing today. Now one set of blades is not spinning.
What is the most likely culprit? Did I break the slip clutch on that side?
   / Hit stump now one blade is not turning #2
it probably has bent the blade to the point where it hitting the housing and won't turn. or you may have busted the spindle. or the splines on the shaft could have striped. have you tried turning the bldes buy hand to see if they are free?
   / Hit stump now one blade is not turning #3
It must have been one heck of a stump! That is a pretty heavy duty mower. Is it possible that when the blade hit the stump, it swung back so far that it got sort of "wedged" at the pivot point, and it is just stuck? I've had that happen to me before. You would notice one heck of a vibration when trying to spin the blades up.
   / Hit stump now one blade is not turning #4
Look at the part and operator manual available online, I don't think you have slip clutches to each side only couplers with the only slip clutch on your PTO. When out Woods 121 did that, it was a broken gear box; sure hope I am wrong.
Had you adjusted your slip clutch this year? If the slip clutch doesn't give, something else will.
   / Hit stump now one blade is not turning #5
The rubber couplers will fail. I had one fail today, sheared all 6 bolts before i got it shutdown.
2015 GMC Acadia SUV (A55853)
2015 GMC Acadia...
2019 TRAIL KING JBTR-49 (A55745)
2019 TRAIL KING...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
HYD FOLD DRAG HARROW (A52706)
HYD FOLD DRAG...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
1974 Honda CB360T Motorcycle (A54865)
1974 Honda CB360T...
