Hitch arms contacting wheels
   / Hitch arms contacting wheels #12
On some of the smaller machines, I think they are Kubota's, the check chains are on the inside of the arms. But I cannot see enough in the pictures to suggest where to connect them on the tractor. On the outer end of the arms, use the holes that are just behind the pins for the lift arms.
I think, based on a thread in the Yanmar section, I have some incorrect parts in the 3ph.
   / Hitch arms contacting wheels #14
On my John Deere 750 (which is a rebadged Yanmar), the turnbuckle/chain assembly mounts to the lower arm in the hole you have between the lift arm and the implement mounting balls.
The other end of the turnbuckle hooks to a bracket on the bottom of the axle right beneath the fender mounts. It's just a triangular bracket with a hole in it for a small clevis pin. There are two mounting holes in the bracket for "wide" or "narrow" implements. For instance, I have to set the chains in the "wide" position for my rotary mower, and in the "narrow" position for my tiller.
I can get pictures if you think it would help.
Some pics might be useful, thanks. Please don't make special trip out with the camera. I won't be able to anything with my tractor until the weekend and/or payday!
   / Hitch arms contacting wheels #16
I remembered it bass-ackwards, the sway chain mount is before the lift arm, not after.
If you need more details, let me know.
HYDRAULIC SKID (A52472)
HYDRAULIC SKID...
2022 MAXEY TRAILER MFG 18 TANDEM AXLE CAR HAULER TRAILER (A52472)
2022 MAXEY TRAILER...
2023 Chevrolet Express 2500 Cargo Van (A51692)
2023 Chevrolet...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
2008 Sterling Bullet Utility Truck, VIN # 3F6WK76A88G352277 (A51572)
2008 Sterling...
2003 Pace American Trailer, VIN # 4FPW540373G068816 (A51572)
2003 Pace American...
