Hitting all the common BX problems
   / Hitting all the common BX problems #62
Is the Kubota Kit K2561-96140 fixing the Gas Tank Leaking over the left Rear. I just purchased my used BX 1800 from local dealer only to find out that I can not use it until I get this leak fixed. What is the solution to the leak?
Thanks in Advance!!
   / Hitting all the common BX problems #63
Hi Tom,
On the throttle not staying at high, the fix is easy.
Take off the black u-shaped grill under the steering column.
Find the double-nut setup on the throttle bolt and tighten as you please.
It worked for me.
Thanks,
Steve
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2019 FREIGHTLINER...
KOOMEY INC VALVE ACTUATOR (A55745)
KOOMEY INC VALVE...
Ingersoll Rand Air Compressor (A52377)
Ingersoll Rand Air...
Giyi 77" Sweeper (A53316)
Giyi 77" Sweeper...
200722 (A51247)
200722 (A51247)
New/Unused 10ft Stainless Steel Workbench (A54865)
New/Unused 10ft...
