Hobart Champion 16 welder/generator ?
   / Hobart Champion 16 welder/generator ? #11
Over the years I've heard many times NOT to use avgas in normal engines because its slow burning, and can overheat your exhaust valves. Typically an industrial engine is low compression, which often run better on regular than on hi-test. Avgas is higher octane than premium.
   / Hobart Champion 16 welder/generator ? #12
I installed fuel shut off valves on my lawn mowers and generators, At the end of the year shut the valve off and run the machines out off gas, Keeps the crud gas we have now from gumming up the carburetor. Works like a charm.
NAPA AUTO PARTS
   / Hobart Champion 16 welder/generator ? #13
BethelH that still is a good way because the float bowl level drops to where the jets suck a little air. Then when you turn gas on again next time "new" gas" mixes & freshens what was remaining in the bowl. Give the mower a good shake before you turn the gas on.
In the old days we used to say "you bought Arco (or no-name)? Dont buy that stuff no wonder it gummed up!" And we used to spray carb cleaner into the carb throat while holding the throttle half open, & watch all the crud wash away.
Well that was the good old days - before multi-billion dollar energy companies had ethanol competing for 10% market share (or 15%?). I suppose back then news agencies would publish advertising as news too, but it seemed like you could tell it was "just an advertisement". Same problems, spun different. Internet has sure changed things.
   / Hobart Champion 16 welder/generator ? #14
Indeed it has changed things, For the better I suppose.
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A55302)
2022 John Deere...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
PAIR OF UNUSED 60" HANG ON FORKS (A54757)
PAIR OF UNUSED 60"...
SCAN TO RECEIVE TEXT UPDATES (A54756)
SCAN TO RECEIVE...
2012 Freightliner M2 Chipper Truck (A52377)
2012 Freightliner...
