$Holy Crap$ - Alternator JD 770
/ $Holy Crap$ - Alternator JD 770 #1
wcpeabody
Bronze Member
earth
JD 770
I just called my local JD dealer and they said a 20 amp alternator for my 770 in >$300.
Does that sound right?
Any suggestions on where to price check them?
Might have to take it in to be rebuilt?
Thanks in advance
Bill
/ $Holy Crap$ - Alternator JD 770 #2
If you buy from Deere, that's the price.
I'd look for a local alternator repair shop though...shouldn't cost too much for a rebuild.
/ $Holy Crap$ - Alternator JD 770 #3
Sounds about right for John Deere. New Holland wants $278 for a small water pump for tractors, TC35, TC40,TC45, TC48, TC55. :confused2:
Thanks for the quick replies. I will take it off tomorrow and take it in for a rebuild.
Bill
/ $Holy Crap$ - Alternator JD 770 #5
I'm not surprised! A new starter for my 83-420 garden tractor (20 HP Onan) lists for over $400 from "Mother Deere"! :(
/ $Holy Crap$ - Alternator JD 770 #6
In case you overlooked it (or forgot), its not that the parts are expensive to get or make, its caused by the simple fact that your money isn't worth what it used to be relative to the foreign currency of the manufacturer.
Anyone care to explain to the nonbelievers why this has happened? We are now a Third World nation in the Manufacturing Sector. Wait until you see what a loaf of bread costs in 10 years. (Hint: Buy wheelbarrow stocks).
OK, now go out and buy another Grey Market tractor...
/ $Holy Crap$ - Alternator JD 770 #7
I seriously boubt the alternator is bad. I have never replaced one of these style unless the bearings go bad. Usually any charging problem is the regulator/rectifier. Or you could have a broken wire or connector.
/ $Holy Crap$ - Alternator JD 770 #8
The alternator in our 2000 Ford Escape is going bad, dealer said $480 to get a new one put in. I'm looking for a re-build shop.
Don't get me started on the fact that you used to be able to replace a diode, then at least the diode pack, and the voltage regulator was also a separate piece.
Pete
/ $Holy Crap$ - Alternator JD 770 #9
Some rebuild shops will sell you the diodes/brushes/regulators you need for a home-brew rebuild if you can't get them somewhere else. Bearings should be easily available. The only thing that might be difficult is cleaning up the slip rings/commutator. I've rebuilt a number of starters and alternators this way and just used some crocus cloth on the armature with long-lasting results. It really isn't too hard to rebuild an alternator, if you can get the parts.
It is seized up.
Thanks,
Bill
/ $Holy Crap$ - Alternator JD 770 #11
It is seized up.
Thanks,
Bill
if it's the bearings they will have numbers on them, bearings are pretty well a standard item
when an item is designed that uses bearings , they look for standard bearings that will fit
/ $Holy Crap$ - Alternator JD 770 #12
Every community has at least one alternator shop. Unless it is completely destroyed, they can rebuild it for much less than the Cost of New.
/ $Holy Crap$ - Alternator JD 770 #13
Find a local rebuilder.
/ $Holy Crap$ - Alternator JD 770 #14
I replaced my 40 amp with a 55 amp alternator. Don't know if the 770 can use the 40 amp. If it can pm me and we'll talk.
-mike-
/ $Holy Crap$ - Alternator JD 770 #15
Water pump for a JD 4000 is 290.00!! Steiner has one for 99.00. I kinda feel guilty, I want to buy local, but 290 VS 99 is a know brainer!!
DAVID,
/ $Holy Crap$ - Alternator JD 770 #16
The 20 amp alternator on my 455 shelled the front bearing last year. I was able to match the bearing number at the autoparts store. $10 later I was back in tall cotton. It took longer to remove and install it than to replace the bearings.
So a quick update. The alternator was rebuilt(what ever that means) locally. It cost just over $60
One thing I noticed I thought was odd, is that it does not spin smooth but I am not sure how to describe it. Almost like it has speed bumps in there???
/ $Holy Crap$ - Alternator JD 770 #18
When the magnets pass the coils there should be some resistance. They is what creates the voltage.
/ $Holy Crap$ - Alternator JD 770 #19
The only thing that went on my 770 was the bearings in the alternator, took it apart and matched up the bearings at NAPA, reassemble and back in business.;)
Don't buy a new alternator until you at least try to have it repaired.
(BTY, it was an easy repair)
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
(100) UNUSED KJ K0311-10' GALVALUNE CORRUGATED (A60432)
(100) UNUSED KJ...
CASE IH MAXXUM 115 TRACTOR (A60430)
CASE IH MAXXUM 115...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
2022 Dodge Ram 4500 Miller 8,000lbs Wrecker Tow Truck (A59230)
2022 Dodge Ram...
