$Holy Crap$ - Alternator JD 770
   / $Holy Crap$ - Alternator JD 770 #11
It is seized up.
Thanks,
Bill
if it's the bearings they will have numbers on them, bearings are pretty well a standard item
when an item is designed that uses bearings , they look for standard bearings that will fit
   / $Holy Crap$ - Alternator JD 770 #12
Every community has at least one alternator shop. Unless it is completely destroyed, they can rebuild it for much less than the Cost of New.
   / $Holy Crap$ - Alternator JD 770 #13
Find a local rebuilder.
   / $Holy Crap$ - Alternator JD 770 #14
I replaced my 40 amp with a 55 amp alternator. Don't know if the 770 can use the 40 amp. If it can pm me and we'll talk.
-mike-
   / $Holy Crap$ - Alternator JD 770 #15
Water pump for a JD 4000 is 290.00!! Steiner has one for 99.00. I kinda feel guilty, I want to buy local, but 290 VS 99 is a know brainer!!
DAVID,
   / $Holy Crap$ - Alternator JD 770 #16
The 20 amp alternator on my 455 shelled the front bearing last year. I was able to match the bearing number at the autoparts store. $10 later I was back in tall cotton. It took longer to remove and install it than to replace the bearings.
So a quick update. The alternator was rebuilt(what ever that means) locally. It cost just over $60
One thing I noticed I thought was odd, is that it does not spin smooth but I am not sure how to describe it. Almost like it has speed bumps in there???
   / $Holy Crap$ - Alternator JD 770 #18
When the magnets pass the coils there should be some resistance. They is what creates the voltage.
   / $Holy Crap$ - Alternator JD 770 #19
The only thing that went on my 770 was the bearings in the alternator, took it apart and matched up the bearings at NAPA, reassemble and back in business.;)
Don't buy a new alternator until you at least try to have it repaired.
(BTY, it was an easy repair)
UNUSED LANDHONOR BH-12-72D BACKHOE DIGGER ARM (A54757)
UNUSED LANDHONOR...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
RHINO 160 - 5' ROTARY MOWER, 3PT (A54756)
RHINO 160 - 5'...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2013 CATERPILLAR 312E EXCAVATOR (A51406)
2013 CATERPILLAR...
