Thanks for the link JJ, when I get my internet useage back I will watch it to the end. This blokes skid steer looks like a good jigger but way to high for what I am after. I have nearly finished one side of my machine and it is only 2 feet high and will probably be controlled from the rear from a platform made from a piece of heavy conveyor belting supported on chains so it can follow the ground. This tractor does not need to be nimble or fast, just be able to get a few hundred pounds of this heavy wet manure out from under the shed each trip to the outside world where the farmer can access it with his front end loader.
Cables and winches sound beaut except these sheds are already packed up to the floor boards with wet manure with no way of feeding cables or scoops from one side to the other.
The bloke who does it around here for a living has a machine similar to a Gokart and can only remove a barrow load each trip, my machine weighs around 1000lbs without counterweights as the main frame is 5/8" plate so it should have a much bigger payload.
My next challenge is to use a car power steering pump to raise the bucket only as the drives are mechanical with clutches. Steve
