I think there is a potential problem here. Lets assume for a moment that #2 heating oil and diesel are basically the same (I believe there are slight differences).
Now, consider the coming ultra low sulphur diesel fuel rules. In the case of diesel fuel, a lubrication modifier will have to be added to compensate for the lost lubricating properties of the sulphur. I'm guessing there is no reason to add this lubricant to home heating oil. If #2 home heating oil is required to comply with the low sulphur regulations (which I'm guessing it will), then why would the manufacturers add lubricant packages at higher production cost?
Swapping one for another could potentially result in excessive wear and damage in diesel engines.
