speedbump
There are two kinds of wells. Screened wells and rock wells. Rock wells and screened wells both need casing to hold the hole open. In screened wells, the casing goes all the way down to the aquifer where ever it may be. Then a screen is put down into the aquifer and is sealed to the casing in a couple of ways. Rock wells are made by putting casing down until rock is encountered. It is driven into the rock a little ways to seal it off. Then an open hole is drilled into the rock until enough water is available. In Florida there is an ocean of water. In the mountains sometimes its hard to find humidity.
The way to look at this is ask yourself why all Well Drillers use a real Drilling Rig to drill wells.
Mikes site "How to drill your own well" is basically for surface water. The method he uses couldn't go to 100'. 40 feet would be a stretch. And the man who said your household water wouldn't be enough to bring the drilling cuttings up was absolutely correct... I'm just trying to save you some money.
