Homemade 3pt Snowblower
   / Homemade 3pt Snowblower #11
Excellent work!!!
Love that gear box too. I can't tell from the pics but is there a way to adjust the gear lash? If not how did you figure out the distance required between centers to have the correct lash. I've been toying with the idea of running my rear mount snow blower on the front of the tractor, driven by the rear PTO. But that would require a reversing gear box like the one you made and I would like to know how to determine the correct gear spacing.
I'm fortunate to have access to a visual measuring machine at work. I setup the gears gently pressed together (no lash) and had the tech measure the center to center distance and it was 4.80000 (yes to 5 decimal places). I added .010 for clearance and machining variation, ended with very little play. Will it last for 100,000 miles? Probably not, but it should outlast everything else on the blower.
Prior to the visual measuring machine, I had thought of grinding some close fit pins and using them to establish center lines. Then use the same process of measuring the gears gently pressed together.
   / Homemade 3pt Snowblower #13
Excellent work!!!
This is an idea for reversing the pto direction for a front mounted blower I found years ago.
This might give you some ideas which do not need specialized machining skills.
Dave M7040
Ooo I like that.
   / Homemade 3pt Snowblower #15
Dave M7040
Thanks Dave. Funny thing is, I've already got that pic saved on my desktop from some previous research I had going on about a year ago, for the same topic.:)
John
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56436)
2-Row Peanut...
2013 Peterbilt 367 QMC 7060S 35 Ton Tri Axle All-Terrain Crane Truck (A55973)
2013 Peterbilt 367...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
