Homemade garden mini tractor 4x4
   / Homemade garden mini tractor 4x4 #182
Don't know if you noticed. Even the lathe/mill machine he makes his parts on looks homemade. You have to appreciate the determination and resourcefulness.
Eggzachery !
How about some background on yourself, and some pictures of your shop, maybe the farm and the area around you ?
Hello! A small assistant helps me build a house. Hydraulics work badly, the pressure in the hydraulic system is not enough. It is possible to replace the hydraulic pump.
   / Homemade garden mini tractor 4x4 #184
Dobre utra.
When a hydraulic pump gets worn, it can't pump up to full pressure. Check the filters first. Maybe fluid got too hot.
Good luck with the house.
   / Homemade garden mini tractor 4x4 #185
The problem might be a relieve valve in the joystick. Check if joystick get hot or emits sound.
My working day. The homemade tractor 4x4 helps me in the construction of my house.
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
Bobcat S740 (A57148)
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
20ft Driveway Entrance Gate w/ Deer Design (A57454)
20ft Driveway...
2012 HEIL (A58214)
2012 HEIL (A58214)
IRanch Wrought Iron Fence (A57149)
IRanch Wrought...
