Homemade road maintenance "tool"
   / Homemade road maintenance "tool" #1
2orodd
norway
John deere 5100m
Hi, this is my homemade road maintenance tool. it is made out off old truck tires and steel cables, all for free :thumbsup: Dont know what you call it "over there". I find it much easier to use this than a grader blade. Because it will not pull up rocks an other stuff, it also follow the terrain in a smoother way.
first round
3rd and last trip :tractor:
   / Homemade road maintenance "tool" #4
More photos. please.
How many tires to make it?
Bruce
   / Homemade road maintenance "tool" #5
:welcome:
"Over here", I'd call that pretty slick! (nice):thumbsup:
   / Homemade road maintenance "tool" #7
I used something similar for years. I have put to together, one 4 sections of a catwalk and one 6 welded together with chain links to attach a drag strap.
Recently built a land plane that works better for filling badly damaged paths.
   / Homemade road maintenance "tool" #9
Yep! I like that.
It has desirable weight and probably will never wear out and conform to minor deviations all while filling in holes.
Being rubber it will ride over obstacles without snagging and bouncing.
Shorten one side to mound towards the center to effect drainage.
About the only improvement I could think of would be to add a spacer between each layer to effectively create multitude cutting edges.
(sort of like a razor, one blade shaves but 3-4 is smother)
   / Homemade road maintenance "tool" #10
Great idea. Best part is you aren't worried about how much money was spent when it's not being used!!!!! :cool:
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
2020 Peterbilt 520 T/A Cab and Chassis Truck (A51692)
2020 Peterbilt 520...
Rogers 4th Axle (A51572)
Rogers 4th Axle...
Hay Spear for Tractor (A51573)
Hay Spear for...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2008 ELGIN SWEEPER (A52472)
2008 ELGIN SWEEPER...
