Homemade road maintenance "tool"
   / Homemade road maintenance "tool" #11
And the scrap metal thieves don't want it.
Bruce
   / Homemade road maintenance "tool" #13
Just filling loose gravel to the bottom of a hard packed pothole isnt a long time cure. Water will collect between the gravel and it will splash out of the hole when driving on a wet road. But all right, if you have a bit of gravel on top of a rocky road, i can see why you dont want to pull stones up and get more work than you started with....
yes that's right, i do have a bit of gravel on top of a rocky/muddy/sandy road. The problem i had with the blade is when the tracktor drives over a bump the blade behind the tractor creats a new bump. This i eliminated with the new tool. and it is also faster to use.
I am not saying it is better than a road blade, but i prefer to use this tool on our road:thumbsup:
left side is the front. As you can see the side walls of the tires are removed. Very important to have the steal wires as tight as possible. At first attempt they were too loose and the "rig" bent in the middel. So i was just dragging the gravel with me.
I also added a small steel beam, to prevent it from bending in the middle. now it is pulling gravel from the side of the road, and pushing it to the middel and creating a curv in the middel of the road.
The aggressive edge is pointing forward. The "tool" is almost 10 feet wide. 3 feet long. It is also very heavy. i am guessing 1800lbs
Next time im driving with it i will try a longer rope on the right side to create a bigger angle on the "tool"
   / Homemade road maintenance "tool" #18
If you hang it under the loader bucket,, you can smooth the road ahead of the tractor.
That will allow the operator to have a smoother ride,,, :thumbsup:
Can you tell I am an old guy that likes to take life easy? :laughing:
Would it be possible to put a runner on one end of the tool?
The runner could lift the end slightly, allowing you to "crown" the road.
If you have any hills, a crown in the center of the driveway is necessary to cause the water to run to the side of the road,,,
rather than running down the road, creating a ditch in the road.
I have been learning how to crown my driveway with a landplane.
The landplane really does not like to crown a road,,, it really wants to flatten the road.
yes have been thinking of putting a runner on one side, but i dont think it is nesesary yet. No problem with the water digging in to the road. But it has been a pretty dry fall.
when i use it, I try to drag it as long as possible out in the ditch. This helps curving the road an also remove things growing near the road :)
   / Homemade road maintenance "tool" #20
The drag behind does work for this but the land plane will as well because you set the depth of the blades and its riding on the skids but depending on the depth of your blades the drag can be more or less likely to "pick up" larger objects, at the expense of less efficient movement of materials (more passes to smooth).
Better have a good dust mask if you run it up front. Once I have the road graded with a crown I run the landplane on each side with the inboard skid riding on top of the crown. If you straddle the crown, it will be gone.
2024 CATERPILLAR 242D3 SKID STEER (A52705)
2024 CATERPILLAR...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2020 CATERPILLAR 299D3XE SKID STEER (A52705)
2020 CATERPILLAR...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
2016 Ford F-250 Ext. Cab Pickup Truck (A53422)
2016 Ford F-250...
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
