Honda fourtrax 350 brake problem
   / Honda fourtrax 350 brake problem
Thanks we travel mainly on gravel and grazing land and i think the k299(bear claws) are usually thought of as the best of the best
Ok loosened all the nuts and bolts on the arms to take off the balljoints. And i had a go at that drum again and i couldnt get the adjuster to move :/ so i still couldnt get the drum off. Ideas?
   / Honda fourtrax 350 brake problem #13
Looks like the adjuster hole plug is on the brake drum on the outside. I originally thought access was at the rear.
And there is some 6x10mm bolts holding the hub to the spindle. These have to be removed.
Will the notch wheel move in either direction?
Did you apply some penetrating oil?
PM your email and I'll email you directly, this may take some time to fix.
And the exact model would be useful. It's a 03/04 TRX350 but is it a FE, FM, TE, TM version. Might make a difference.
KOOMEY INC VALVE ACTUATOR (A55745)
KOOMEY INC VALVE...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A53421)
2025 ZWB 59in...
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
Giyi Hydro Pallet Forks (A53316)
Giyi Hydro Pallet...
Wooden Rack Hay Wagon (A50775)
Wooden Rack Hay...
