Honda GX390 in the winter, not good
   / Honda GX390 in the winter, not good #11
Also try ethanol-free, if possible, at least in cold weather.
You should never run ethanol gas in a small engine if you can help it. It deteriorates fuel lines and clogs the system
Yeah, I use premium from the gas station nearby that a local small engine shop swears by (for this reason.)
Any Honda dealer in your area should be able to get you a cold weather kit. I'm also in ontario and have seen numerous berco/ kimpex ATV snowblowers with hondas that experienced similar issues with the govenor linkage. The cold weather cured them all
I'm totally going to investigate this, thanks! This is driving me batty.
So it's just a mechanical problem with the fuel linkage? Does it freeze up after the engine has already warmed up?
Correct yeah. Engine can be running for a while, governor freezes up, starts surging or loses power; generally runs terrible and/or dies.
   / Honda GX390 in the winter, not good #16
Yeah on the gas. If by premium you mean around 92 octane... dont. You need to run a lower octane in that engine...87-89 but yes...high quality non-ethanol most importantly. The guy above said the cold weather kit works well. Also maybe some sticky lubricant on the part that wants to freeze.
Im from Alabama so we definitely have different weather problems. My wife is from New Brunswick, though!
   / Honda GX390 in the winter, not good #17
I have NO problem running 92 octane in my small engines, and that means from chainsaws, 13hp Honda, 8 horse on up Kohlers and Tecumseh...
In fact, the Vanguard on my BSM runs the best it ever has, on premium fuel.
SR
   / Honda GX390 in the winter, not good #18
SR
No it's not necessarily going to give problems but in principle, low octane is suited for lower compression engines and high octane is suited for high compression engines...like chainsaws. Octane is increased by an additive only to control the intensity of combustion. It does NOT increase power. You'll actually lose a little bit in lower compression engines.
   / Honda GX390 in the winter, not good #19
SR
I use 100LL from the local airport.
non ethanol gas not sold in the state.
Small engines run great on 100LL, even my 8N.
   / Honda GX390 in the winter, not good #20
must be unique to the way its mounted? i just picked up a hss1332 and it has no issues linkages are covered and it ran fine in 25F, and i use ethanol, 0 issue like usual
New/Unused 30in Rolling Service Cart (A54865)
New/Unused 30in...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A57024)
2010 Ford F550...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2007 FREIGHTLINER COLUMBIA 120 (A55745)
2007 FREIGHTLINER...
Toro Reelmaster 5400-D Fairway Reel Mower (A55851)
Toro Reelmaster...
