Hooking Up the Battery on a Modified 1951 8N
   / Hooking Up the Battery on a Modified 1951 8N #11
I wonder if you took the alternator or the generator to a rebuild shop if they wouldn't be able to tell if it was positive or negative ground.
Thank you, K7LN!
Mine looks like the lower right picture, so it's an alternator. I presume the positive lead from the battery is the one that should be headed to the alternator.
When I have a chance, I can head out and also check the lead to the points, per an earlier suggestion.
Thank you again!
OK, I'm hoping the solenoid is connected to the alternator to eliminate any doubt in my mind. I only disconnected the end of the cable at the battery, so the other end should still be in the right place. :thumbsup:
9000 (A47477)
9000 (A47477)
2012 TAKEUCHI TL12 SKID STEER (A60429)
2012 TAKEUCHI TL12...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
Great Dane Van Trailer 1989 (A56438)
Great Dane Van...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
