Horse Manure & Pine Shavings: Nitrogen Thief
   / Horse Manure & Pine Shavings: Nitrogen Thief #11
Now I know you are pulling our leg. I tried that and it didn't work! /forums/images/graemlins/confused.gif Maybe the tree was too big and too old?
   / Horse Manure & Pine Shavings: Nitrogen Thief #12
You have to give it a big drink of water.... did you remember to do that? Otherwise, it will just get stuck and the roots will be sticking out .. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Horse Manure & Pine Shavings: Nitrogen Thief #13
Cowboydoc, do you composte the shavings/manure before you spread it or do you spread it right out of the barn? Most of the nitrogen that the horse gives up is in the urine. That is lost pretty quickly as it turns to ammonia and evaporates. The shavings use up a lot of nitrogen as they decompose.
From UMontana....
"Sawdust and wood shavings are rich in carbon like wood chips, and they have more surface area for bacteria to work on than chips do, so these materials tend to rob more nitrogen from the soil or compost initially. Sawdust should be aged/weathered before adding it to the compost pile. To balance the demands of one cubic yard of fresh sawdust, add 3 1/2 pounds of actual nitrogen (17 lbs. Ammonium sulphate, 15 lbs blood meal, 11 lbs. ammonium nitrate, or 8 lbs urea)"
Umontana
Another is the "bible" for berry farmers... The Backyard Berry Book by Stella Otto. On page 66, she says: "One important point to remember when using any natural plant matter as mulch, is the need to provide extra nitrogen to the garden. Soil organisms that break down these mulches use considerable nitrogen in the process. If additional nitrogen is not supplied to them through supplemental feeding, they will compete with the fruit plants to use what is already in the soil."
Hope that helps. I try to composte mine for a year before I spread it.
1997 CATERPILLAR 120H MOTORGRADER (A51406)
1997 CATERPILLAR...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A54607)
2007 POWERSCREEN...
Utility Trailer (A52377)
Utility Trailer...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
