Horsepower question
   / Horsepower question #11
I have a L3400 with R4 tires with Rimguard and FEL that I use for food plots. Our ground is very sandy and hilly. The L3400 will pull the 6' disc as deep as I want it on level ground, but up the hills I have to really nurse it. The tractor is a hydro and starts to lose power as it goes unless I ease off on the depth. I'm guessing this is mainly a horsepower issue as I can drive up the hills without much power loss with the disc up. I need the R4 tires as I use the equipment on our lawn occasionally so R1's are not a viable option for me. The disc is a Land Pride 3 pt with 18" disc's and weighs 985 lbs. How much more HP do I need to not have to worry about the uphill trips. I don't have an unlimited wallet "unfortunately" so I want to get something that will work but not overkill. After just talking to a dealer he said I would need to go to 50 HP. I am getting something with a cab but looking for any suggestions.
In your other thread you mentioned the Deere 4320 cab, I would recommend you spend a few more bucks for the 4520 cab that is a 12hp increase and should be very noticable improvent when going uphill. The 25% increase in power really helps imo. The faster your ground speed is the more you will notice the difference the extra hp will make.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
2014 Dodge 5500 4X4 Bucket Truck (A55218)
2014 Dodge 5500...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A55218)
2-Row Peanut...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
