kebo
Elite Member
- Joined
- May 16, 2006
- Messages
- 2,928
- Location
- Lexington, SC
- Tractor
- 2001 John Deere 790 4x4, bar tires
Those are some pretty good sized tusks on that hog! How much did it weigh??
thats a monster size skull. Was the meat any good on one that big?
I'm guessing screwshaft, nut assembly failure of some type. Are we talking the same thing?
While steering left it would not catch but I could step left and get it to go left. But sometimes depending if I was holding right pressure on the wheel it would lock a few degrees left and no matter how hard I stomped left on the drag link end it would not go any further left.
That made for a pretty hairy trailer load and unload!
the steering shaft is called the wormshaft.. the assembly that runs the wormshaft and engages the double sector gear is the ballnut.
might have been a bad upper thrust bear that has come apart as well as the top bushing in the steering column, allowing excessive ballnut to sector clearance, plus letting rollers drop into the gears.
soundguy
wow.. I've never seen a steering wheel hub rusted out soo bat that it let rain water in!.. it wouldliterally have to be rusted out at the top of the hub, unless the top had perforated.. or the column tub had a hole in it.
usually what happens is the sector seals leak and that make sthe lube level low.. then someone runs the tractor like that for 50ys.. then the upper thrust bearing wears out and disintegrates and rollers drop into the box. this usually lets the wormshaft have up/down play, and that beats ont he lower thrust bearing, and that also allows the top bushing at the top of the column to hog out.. this lets the wormshaft and ballnut set at an odd angle to the sector gear.. thus making steering have play and be hard to steer due to being in a bind, and no bearings.. and rolelrs falling into the sector gears. I think I have rebuilt just about every steering box on every ford I have save my 2n and 5000..
soundguy
