Hour Meter tachometer cable broke SC2400
   / Hour Meter tachometer cable broke SC2400
I found this at Hoye tractor using their search. The holes are angled opposite but looks pretty close. Been awhile since Ive been inside my meter and cant remember how it connects inside. You may want to call and see if it measures up.
TACHOMETER DRIVE UNIT: Yanmar Tractor Parts
   / Hour Meter tachometer cable broke SC2400 #12
SS White makes speedometer cable and ratio box replacement parts
Sent from my iPad using TractorByNet
   / Hour Meter tachometer cable broke SC2400 #13
An experimental pond rake - had some stuff laying around and thought I would create a rake for the pond that would float along the bottom - like a drag.
:drink:
   / Hour Meter tachometer cable broke SC2400 #14
Hey guys thanks for the ideas - Will definitely explore all, that tach drive maybe close - I just bought a Tiny Tach for a diesel DTL6 (tach and hr meter) probably install it tomorrow - But I sure would like the OEM stuff working - the search continues
   / Hour Meter tachometer cable broke SC2400 #15
Thank you so much! I have successfully replaced the cable on my SC2400. Found one here for a John Deere that was 6 inches longer but it works fine.
   / Hour Meter tachometer cable broke SC2400 #16
I followed the procedure to the 'T'. Found that my bushing was seized too at 315 hours. The 3-in-1 took care of the binding and I greased the right angle gears.
Got a new cable based on SC2400Cree's link above. Price was right and delivery was good.
I went from a broken tach to repaired unit in 6 days for about $20. Thanks everyone!
   / Hour Meter tachometer cable broke SC2400 #17
Capt (removed). I used your fix for sc2400 tach cable.It was a seized bushing.Thanks for all the detail.Works great..
1999 CPS TRAILER COMPANY BELLY DUMP TRAILER (A58214)
1999 CPS TRAILER...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
KIOTI SL7504-PL SKID STEER (A52709)
KIOTI SL7504-PL...
2005 PETERBILT 379 (A58214)
2005 PETERBILT 379...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
2347 (A58376)
2347 (A58376)
