How are the MMM with buildup?
   / How are the MMM with buildup? #11
Got my 2660 in December, and am looking forward to spring and the grass cutting season. My old JD LT-180 required hosing out after every other cut (~2 acres each).
How do the Kubota decks fare when it comes to clippings building up under the deck?
Ian
hmm you mean compare kubota MMM to the el cheapos tractors? I really dont think there is a difference. Maybe a little- Some cheapo tractors dont have much buildup, others have so much buildup due to shape designed. I would have to say that kubota MMM is on the better side. You still need to scrape it in couple spots, but other wise its pretty good.
   / How are the MMM with buildup? #12
Don't mow when it's wet? Seems to be the cure for any mower I've owned, mid, rear, or otherwise.
Would not work here as when the grass starts growing it needs mowing every 5-6 days and the rain does not stop for mowing windows.
David Kb7uns
   / How are the MMM with buildup? #13
Leonz: I know you always push the flail mower. Which flail mower do you own?
Mathews Company Lawn Genie 48" 16 H.P. Briggs and Stratton I/C with a cast iron piston sleeve- they do not make these mowers or engines any more and its a shame too.
I can still get engine parts which is nice as I would have to buy a Briggs Vanguard twin to replace it.
   / How are the MMM with buildup? #15
I only clean once a year in the fall, not much to remove. Says it all!
   / How are the MMM with buildup? #16
same here not much hangs in there,when I mow when its real wet it will stick but comes right uot the next time I mow. When I remove it in the fall always do a real good cleaning while its sitting on tthe stand wheels.
   / How are the MMM with buildup? #17
Sounds interesting. Show pictures please.
   / How are the MMM with buildup? #18
I do get a fair amount of buildup, but it doesn't affect performance all that much. I just scrape it off once a year when I remove and sharpen the blades.
   / How are the MMM with buildup? #20
I've used my BX2660 for two seasons with the MMM. I only had lots of buildup once and that was after mowing very wet grass. Otherwise its never been a problem mowing less than 2 acres.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A50505)
2018 FREIGHTLINER...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2016 Chevrolet Silverado 1500 Custom Crew Cab Pickup Truck (A48081)
2016 Chevrolet...
2015 Ford F-750 Crew Cab Liftmoore 2550 5000LB Mechanics Crane Truck (A48081)
2015 Ford F-750...
Peterbilt 377 Semi-Truck (A50397)
Peterbilt 377...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A50397)
Mitsubishi FG35...
