How big a hole can you repair in tire?
   / How big a hole can you repair in tire? #11
With a low speed tractor tire, repairs seem to last longer, not as much stress on the tire as would be on a highway tire. I had a tire with a 3/4" hole in it, so I put a 3/4" bolt through it, ground down corners of the bolt (on the outside), put a big patch on the inside, then a fender washer, then a 1/2 thickness nylon jam nut, then a blowout patch, then a chafer tube, then a regular tube, repair worked for 5 years, then sold the tractor, it was still holding air! Had a hillbilly neighbor that patched a split in a JD B rear tire with 2 pieces of steel with 2 holes drilled through them, 2 bolts held it together for 15 years or more, but you could hear him coming down the road for a couple of miles, pop-pop-clank, pop-pop-clank, etc!:p :p :p
   / How big a hole can you repair in tire? #12
I once plugged a hole in my own tire on my truck that required 3 plugs. The bolt was over 1/2". The repair last the rest of the life of the tire too. I have plugged many tires as a wrench back in the day, but I wouldn't not do 3 plug repair on a customer's vehicle. Yeah, people are going to say that plugs are not correct, but I have never had or had complaints from plugging tires.
Dan
Well, the repair I made to the tire yesterday has held up for one day anyway.:) I did a fair amount of backhoe work and took the tractor through the woods today without incident. Keeping my fingers crossed.
2013 VOLVO VNL DOUBLE BUNK SLEEPER (A43004)
2013 VOLVO VNL...
Kobelco SK300 Excavator (A44391)
Kobelco SK300...
2001 Ford F-250 Ext. Cab Pickup Truck (A44572)
2001 Ford F-250...
2018 Toyota 8FGCU32 Forklift  Reliable Performance with Low Hours! (A46877)
2018 Toyota...
2023 New Holland Workmaster 70 (A44391)
2023 New Holland...
Ryobi Router Table (A44391)
Ryobi Router Table...
