How BIG a splitter do I need for this project?
   / How BIG a splitter do I need for this project? #21
aczlan
I only wish I had access to a splitter that powerful:licking: the chips would really fly.
Its not super powerful (10ish HP engine running a 2 stage pump) but it is big (they started with a 12' long 10" wide x 12" tall I beam), has a drop down leg in the back (so it doesn't tip when loading big logs) and has a log lifter.
Aaron Z
   / How BIG a splitter do I need for this project? #22
Thanks for the details on making a glut. My dad and I made sling shots from dogwood. He helped me strip the bark and bake the forked branches.
I looked online for a splitting glut and of all things Roy Underhill of The Woodwrights Shop, produced here in NC, had instructions on making a glut.
Seems like my FIL spoke of using black locust for gluts.
   / How BIG a splitter do I need for this project? #23
First time I have seen the term "Glut" used in a long time. We used to split Locust for fence post. The splitting was usually accomplished using a 16lb sledge and metal wedges to start the split. We then would use a glut and wooden maul to run the split the full length of the post. While dogwood would make a good "glut", we usually would just saw off a length of the locust post we where splitting, sharpen into a long wedge using the chainsaw. Locust would last forever, but I have used dogwood, hickory, oak, and even pine whenever I needed a quick wedge to split something with.
As for those large rounds that need splitting. I built my hydraulic splitter with a 2ft tall wedge and if you took a Fel and a set of log tongs to set those rounds on it, I can make splitters out of it pretty quick. To heck with twisting and turning something that large to split in a vertical splitter
   / How BIG a splitter do I need for this project? #24
Arkaybee
I think you are using what you have well. I was going to recommend going up to an 8 pound sledge until I got to the part about your age. :laughing: My 8 pound splitting maul is about all I want to swing anymore, and you have 11 years on me.
That's going to be some great firewood once it is split and dried. I wouldn't kill myself on the gnarly pieces, just whack them up with the saw or use them for a weenie roast in a fire pit.
   / How BIG a splitter do I need for this project? #25
when i was a teenage i split rounds 8' in diam with nothing more than 2 wedges a splitting maul, a sledge and an axe.
oh and grind off those mushroom caps on those wedges before you wind up with a chunk of steel in your leg. I learned my the lesson the hard way when a chipped off a 1/4" chunk and the only thing that saved me was the kevlar chaps i still had on.
   / How BIG a splitter do I need for this project? #26
Iv done it with my 18T. Never a problem beyond handling the 900lb rounds.
larry
   / How BIG a splitter do I need for this project? #27
I'll go ahead and second this. I've got a piece of steel in my left thigh that will set off a metal detector. :(
   / How BIG a splitter do I need for this project? #28
I always wondered how a electric jackhammer with the right bit would work splitting big blocks.
   / How BIG a splitter do I need for this project? #29
Arkaybee....couple of observations:
1) Kudos to you for taking on such a project. I am 11 years your junior and doubt I would have the kohunas (sp?) to tackle such a project.
2) Your communication/writing skills are excellent. I enjoy your skillful use of words. What was your chosen profession? I expect you were successful given how you possess that rare talent.
dave 1949:
There is an 8-pound sledge in my arsenal but after picking it up recently I quickly dismissed the thought of using it and chose the 6-pounder. Besides, the 8-pounder had no handle--wonder how that happened:rolleyes:
schism and ductape:
Thanks for the reminder about the mushrooming tops of those steel wedges. I have been thinking the same thing--that they need to be cut off.
Triptester:
Good idea on trying the electric jackhammer and if I had one I would certainly try it. I think it might work.
TNhobbyfarmer:
Well, now, you really know how to pour syrup on the cornbread, don't you. That's good old southern vernacular for a generous and favorable compliment or as they also say "laying it on thick."
Your kind remarks are much appreciated. It takes just a little more effort to write with clarity and to do a proper spell check and then to rewrite to improve the narrative. I enjoy telling a story clearly. And I do love expressive words.
It has been almost twelve years since I retired as a professor in a graduate school . I retired because of illness and have had several surgical procedures in the intervening years. After a vertebrae fusion I thought I would not be able to do hard physical work again but the Lord has blessed me with strong recuperative powers. It took over a year before I begin to think that I might be able to regain my physical abilities. Slowly, my body has responded positively and that is why I decided to try this wood harvesting experiment. Besides, the wood was just too pretty to let go to waste. And I REALLY ENJOY the challenge of splitting wood, especially the old school way. Each piece is a new challenge.
The heroes of my youth were the hard working farmers and wood-cutters who did impressive things with only simple tools and the power of the horse . I am a big fan of Roy Underhill and The
Woodwright Shop
on TV as well as his books. The Foxfire series of books are favorites also.
Arkaybee
TANK MANIFOLD (A58214)
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A57193)
UNUSED RAYTREE...
2013 Dodge Charger Sedan (A55853)
2013 Dodge Charger...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
