Dirt Moving How big of a disc will a MF175 pull?
   / How big of a disc will a MF175 pull? #11
A pull type disc likely will be better for leveling especially if your ground has hills/rolling.
   / How big of a disc will a MF175 pull? #12
If you decide to disc then harrow, do the harrowing on a diagonal to the discing to help level the paddock.
I strongly reccomend a hydraulic adjustment if you go the pull disc route. It is much easier to turn at the end of a run without digging holes than a manuel disc.
I have not used a 3ph disc so can't comment.
2017 International WorkStar 7300 Rosco Maximizer 3B 1,900 Gallon Asphalt Distributor Truck (A52377)
2017 International...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
1265 (A50490)
1265 (A50490)
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
2014 John Deere 244J (A47477)
2014 John Deere...
2013 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2013 Ford F-550...
