How can you tell if hydraulic pump is starving?
   / How can you tell if hydraulic pump is starving?
normde2001 said:
"I suspect that you have an inch of gunk on the bottom and new fluid works good until it picks up the gunk again."
My thoughts also, Ernie, assuming there is also a problem with the 3ph. I would also make sure the servicing stop valve is not partly closed.
I GOT IT!
I cycled the service valve several times from full closed to full open while operating the 3PH a few times, and the loader started working perfectly again.
FWIW, there wasn't any gunk inside the transmission sump where the screen filter is, the fluid is very clean.
I want to sincerely thank everyone for the ideas and suggestions. I just came in for lunch and the road is almost cleared enough so we can get out.
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
Swict 84" Bucket (A50121)
Swict 84" Bucket...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2014 Ford F-250 Extended Cab Knapheide Service Truck (A50323)
2014 Ford F-250...
Mi-T-M AS6-HE15-120M 175 PSI Air Compressor (A50322)
Mi-T-M...
