How close should machined gears mesh? Need advice.
   / How close should machined gears mesh? Need advice. #11
looks good from 1000 miles away ... :)
should be much better than before ...
   / How close should machined gears mesh? Need advice. #12
How does this look, at least for starters? I made it tighter than it was but not as tight as my first photos. I didn't try the typewriter paper yet but understand the concept.
How does this clearance look? Tight enough? A little too loose?
Looks like the clearance of the ones on my baler. They work fine. How did you make the adjustment?
It's on the end of a shaft that holds seed cups. One end (with the gear) is supported by a bearing held in a bracket so I just loosened the bracket and pushed it up a little. That's how the adjustment is made and it's one of those three handed efforts. I'll use it for a while and see what it looks like then.
Thanks everyone for the great advice.
2020 Kubota SVL 75-2 Skid Steer (A51573)
2020 Kubota SVL...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
1996 CLEMENT END DUMP TRAILER (A52472)
1996 CLEMENT END...
2006 International 9400i (A52748)
2006 International...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
