How do I add Hydrolics to F1145
   / How do I add Hydrolics to F1145 #1
DP Property
BelleRiver, Ontario
Kubota B7510, JD GT235, JD 757, JD Gator 850D, JD 3720 hi-spec cab on order
Hello guys I am new to this forum. I am buying a used F1145 john Deere today and my main interest is turning it into a sidewalk snow machine. It has a 72 inch front deck on it now and thats it.
Any of you familiar with this machine? what do I need to do to run a small plow on the front with angle left and right. Any of you know how this should be set up on this machine?
Thanks
David
DP Property Maintenance
BelleRiver, Ontario
   / How do I add Hydrolics to F1145 #3
He might want a snowblower but he is asking about a plow.
   / How do I add Hydrolics to F1145 #4
You are so right , I deleted my post.
   / How do I add Hydrolics to F1145 #5
Pretty simple...
The valve bank installed in the tractor already has the 2nd spool...you just need to buy the 2nd lever (Outer), connecting link & new (longer) bolt to put it together...Everything you need including pics is on JDParts....
Then you just need to have some hoses made up to go from the valve bank to the front of the machine.
I purchased the JD Hydraulic Couplers & Bracket...
Here is a pic with where the bracket goes...you can see the Red & Yellow dust caps on the couplers...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2018 John Deere 5075E MFWD Tractor (A53485)
2018 John Deere...
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
ST225/75R15 Trailer Tires (A55787)
ST225/75R15...
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A53421)
2025 GIYI VR66...
