How do I clean out used hydraulic hoses?
   / How do I clean out used hydraulic hoses? #21
gabby said:
The hyd. motor on my centrifugal water pump can only pump water in one direction so I guess that's why it has a check valve.
If the motor on the auger in question is reversible that's good. Won't really matter how the hoses are hooked up, and you can always reverse the auger if it hangs a root and the 3ph can't raise it up out of the hole.
The reason your pump is that way if you spin it inreverse the impeller will un screw off shaft.
tommu
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
2018 Kia Optima Sedan (A55973)
2018 Kia Optima...
MURRAY PUSH MOWER (A55745)
MURRAY PUSH MOWER...
2012 Ford F550 Service Truck (A52377)
2012 Ford F550...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
