How do I dig w/the FEL?
   / How do I dig w/the FEL? #21
Champy said:
... BTW - its a locust tree so its very thorney.
I am dealing with a bunch of those, too. Some are saplings, but I have a few monsters. It is very, very, very rewarding to toss the cut and split sections into the Buck stove.
   / How do I dig w/the FEL? #22
Champy said:
My mistake was thinking that I could simply curl the bucket like a backhoe and begin tearing up loads of turf/dirt. From the feedback, it is clear I need to take smaller shallow layers at a time.
Your thinking is right if your tractor has enough power and traction to push the bucket through the turf/dirt. The BH doesn't just simply curl the bucket. The hydraulic force on the dipper arm forces the bucket through the dirt. You just don't have enough power or traction to push a 5' bucket through the dirt. It would take a small dozer to do that.
   / How do I dig w/the FEL? #23
My best success at taking out small trees is to run up against them a couple inches or so above the soil and upcurl once the front of the FEL bites into the bark a bit. I often need to make 2 or 3 tries at it, because it has to be just so to get enough bite and upcurl at the right point, but I often get them out of the ground, roots and all. Or I mangle them enough so I can back the brush hog over them. Tighten up your top link on your brush hog if you really want to do them in. Just drop it slowly over it. Your brush hog should take out up to 3" or so.
I haven't had much luck digging into the dirt very deeply with the FEL, even with the tooth bar in place. It takes a whole bunch of hp and probably more weight to get that big thing down and back up, with it stuck in the dirt.
Ralph
377789 (A51573)
377789 (A51573)
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
6 FOOT UTILITY TRAILER WITH MOTOR (A53843)
6 FOOT UTILITY...
2015 INTERNATIONAL DURASTAR 4400 WATER TRUCK (A53843)
2015 INTERNATIONAL...
40' CONTAINER (A51244)
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
