Mowing How do I get the bush hog to operate on Yanmar 1500D?
   / How do I get the bush hog to operate on Yanmar 1500D? #11
Don't know that the 1500 is setup like the 2000. But push all the way down to shift into 1st. gear. Neutral will be one up then 2,3rd..
It's similar. Forward for 1st, back for second and i can't remember if it's down and forward or backward for 3rd, never used it.
   / How do I get the bush hog to operate on Yanmar 1500D? #12
does it have the over-run clutch adaptor? if not, it needs to have one otherwise it can be a bit tricky getting started and stopped, ;)
   / How do I get the bush hog to operate on Yanmar 1500D? #13
Its just like the Ym2000 carey. It should be right at your left heel when sitting on the seat. Have the clutch in and push that lever all the way down till it engages, sometimes it kind of hangs inbetween and i have to barely let out the clutch while pushing to engage the lever. Your off to go.
This also assumes that a shear pin on the bush hog dive shaft has not sheared. But i think you just forgot which lever you need.
The two levers between your legs are high (H) / low (L) selector and the actual gear number for the middle one.
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
Air Compressor (New/Unused) (A59225)
Air Compressor...
SCAN TO RECEIVE TEXT UPDATES (A52709)
SCAN TO RECEIVE...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
2020 MACK P164T (A58214)
2020 MACK P164T...
1991 FORD F-800 BED TRUCK (A58214)
1991 FORD F-800...
