How do I know if my Clutch(es) are going?
   / How do I know if my Clutch(es) are going? #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
The service manual for my old '84 L275 kubota only tells how to check when the clutch is out. I'm also having an oil test done; just trying to determine the condition of the tractor, so I can decide whether to keep it and spend a little money fixing details, (New water pump, wiring harness, seat,...) or sell it.
   / How do I know if my Clutch(es) are going? #2
As long as you have the proper freeplay and the clutch holds the torque of the engine, it should be ok. you will notice slippage in the upper gears long before it will slip in the lower gears. For the pto, the same applies.
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2006 FORD F-150 PICKUP (A54313)
2006 FORD F-150...
2001 JOHN DEERE 310G BACKHOE (A52705)
2001 JOHN DEERE...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
1838 (A51248)
1838 (A51248)
