How do I know if my glow plugs are working?
   / How do I know if my glow plugs are working? #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
   / How do I know if my glow plugs are working? #2
3 ways:
1.Take a test light, ground one end, put the other end on the wire to each plug, activate the glow plug circuit. The test light should light (shows they are getting power only).
2. Pull them all out, hook up to battery, see if they glow.
3. If the ambient temp is under 40, and the engine starts on the 3rd or 4th revolution, they are working.
   / How do I know if my glow plugs are working? #3
I'd like to add one obvious warning to #2, DONT TOUCH THEM!!! They get glowing red hot. /forums/images/graemlins/grin.gif
Also , if you have an amp meter, you could hook the inductive clamp over each wire at the plug. Cycle the switch and monitor the amp draw. I'm not sure of the draw of your particular plugs but on a Ford truck they typicaly draw 50A each when cold.
   / How do I know if my glow plugs are working? #4
Good advice on checking them. Note that I've NEVER had a glow plug problem in driving Benzes 195k miles on the first one and coming up on that mileage on the current one.
In my experience, if they're working and the engine compression isn't gone by WAY too many hours or miles, and if you work them the prescribed time (about 5 seconds with the newer ones), the engine starts on the first turn, even at -20 F. This was the case even on my old 1973 Benz. On it, you had to run those old glow plugs for a minute or so at -20 F.
Only diesels with glow plugs I had trouble starting were a couple of rental ones in cold weather (which isn't all that cold) in Sicily. Both the Fiat's and Opel's odometers had gone around the bend a few times.
Ralph
<font color="blue"> If the ambient temp is under 40, and the engine starts on the 3rd or 4th revolution, they are working. </font>
That's definately not happening. At warmer temperatures there's an obvious difference in starting when I use the glow plugs vs. when I don't. Now that it's cold, though, it's taking a while to get her started.
Do glow plugs usually just go out altogether, or do they get "weak" before they go out?
   / How do I know if my glow plugs are working? #6
With glo-plugs there is no in between. They are either good or (open) bad. Think of a filament in an incandescent light bulb.
   / How do I know if my glow plugs are working? #7
You might have one or two that are not working and that will make it considerably harder to start.
Disconnect the wire from each of them and use a continuity tester to see if any are open, i.e., dead. A beeping multimeter is perfect for this, otherwise look for infinite resistance.
   / How do I know if my glow plugs are working? #8
Here's one I have experience with. If you are getting 12 volts to the glow plugs from the wiring harness, take a 12 volt test light, the one with the bulb in the handle and connect the wire to the + of the battery. Touch the end of the glow plug with the probe and if the lamp lights up, the glow plug has resistance and should work. If the lamp doesn't light up the glow plug has no resistance and should be replaced.
If you have a 4 cylinder diesel and one or two plugs are bad, it will make cold starting a real chore.
HTH
Leroy
   / How do I know if my glow plugs are working? #9
</font><font color="blue" class="small">( Here's one I have experience with. If you are getting 12 volts to the glow plugs from the wiring harness, take a 12 volt test light, the one with the bulb in the handle and connect the wire to the + of the battery. Touch the end of the glow plug with the probe and if the lamp lights up, the glow plug has resistance and should work. If the lamp doesn't light up the glow plug has no resistance and should be replaced.
HTH
Leroy )</font>
I wouldn't take this to the bank.... You are reading the voltage drop on the wire going to the glow plug. If it was designed right and is fairly new, no bad connections this drop could easily be less than a volt and won't light the bulb. Iffy test at best...
   / How do I know if my glow plugs are working? #10
I would just add that you should check it to a good ground first, then the glow plug. I woud still ohm them out. If you have an amp meter, this works the best.
   / How do I know if my glow plugs are working? #11
Say again /forums/images/graemlins/confused.gif with the test lite hooked to the bat.+ you have taken the wire out of the circuit,right?
   / How do I know if my glow plugs are working? #12
If the glow plugs are wired in parallel and you don't disconnect them, won't the current find it's way through to any working glow plug? Maybe I missed something, but I think you have to isolate glow plugs to test them and this means disconnecting their wires.
   / How do I know if my glow plugs are working? #13
Maybe I wasn't too clear on this procedure.
This test is done if you are already reading 12 volts at the glow plugs feeding from the wiring harness. You're not reading the voltage to the glow plug, You are reading the glow plug resistance. No resistance, no glow (means the glow plug is open and should be replaced.)
On edit yes the glow plug harness has to be disconnected from the glow plug.
Hope this clears up any banking confusion /forums/images/graemlins/smile.gif
Leroy
   / How do I know if my glow plugs are working? #14
you need to know your system. their are different voltage systems. My old kubota has 10.5 volt glow plugs, my iseki has 9.5 volt system. they have a resistor to drop the voltage. I think Ford uses two different voltage systems in their trucks.
2002 Miller Trailblazer 301G Towable Welder Generator (A59228)
2002 Miller...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
New Holland S68 Square Baler (A56438)
New Holland S68...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
TANK MANIFOLD (A55745)
2013 GREAT DANE 53FT REEFER TRAILER (A59905)
2013 GREAT DANE...
