How do I pull this pulley wheel off ?
   / How do I pull this pulley wheel off ? #21
I was in a similar situation last spring removing a large pressed steel pulley from the gear box of my Landpride rear finish mower. I tried everything; penetrating oil, heat, supporting the outside of the pulley and hearing plus tapping on the shaft, even a large gear puller (could not apply a lot of force because of the danger of bending the pulley). What finally worked for me was to use a dremmel tool and a sawzall to cut a slit in the hub of the pulley just above the keyway. This allowed the center to expand enough to slide easily from the shaft. Once the pulley was off I cleaned everything and prepped the pulley for welding. I put the pulley back on the shaft. It seamed a real good fit. I do not think the center hole had permanitly expanded. I tacked the pulley while it was on the shaft then removed it and finished the weld. It worked great.
Bell B30E (A50123)
Bell B30E (A50123)
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
UNUSED DIGGIT 6'5"-10 DRAWER, 2 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
2011 Retesa CT7622 150 Tri-Axle Vacuum Tanker Trailer (A52377)
2011 Retesa CT7622...
Bush Hog 9670 8FT Pull Type No Till Grain Drill (A55218)
Bush Hog 9670 8FT...
1838 (A51248)
1838 (A51248)
