How Do I Remove Aged/Dried Duct Tape?
   / How Do I Remove Aged/Dried Duct Tape? #11
Many of the milder things would work if you let it soak in. But it might also soak into the adhesive of your decal.
Another product is contact cement solvent or remover.
   / How Do I Remove Aged/Dried Duct Tape? #12
Lighter fluid (no fire!) is a little better or stronger than GooGone and not as harsh as acetone. Most of the time you will need to get it wet and then scrape it into the glue etc so the fluid soaks in.
Agreed, zippo fluid is what a book collector I knew used. No damage to the dust jacket but stickers would come right off. I've been using for years since I saw him use it.
I got some lighter fluid,, I will try that,,, at least, it will remove the PB Blaster!! :laughing:
   / How Do I Remove Aged/Dried Duct Tape? #14
I have had real good luck with "Goof Off" and waterless hand cleaner like Gojo. soaking, soaking soaking.
I gotta say this looks like a tough one to tackle but you WILL get that crud off sooner or later.
   / How Do I Remove Aged/Dried Duct Tape? #15
I've used a product called Goof-Off to remove materials like duct tape... Ok, nothing is like Duct Tape, got it... but Goof Off has worked well for me on any kind of sticker/tape residue. I also recommend, as others have, using a plastic scraper. Takes a few soak-scrape cycles then wipe it all down with some Windex.
   / How Do I Remove Aged/Dried Duct Tape? #16
I've always used lacquer thinner, putty knife and a GOOD pair of rubber gloves. Lacquer thinner is carcinogenic - use with care. In your case - try a heat gun and putty knife.
   / How Do I Remove Aged/Dried Duct Tape? #17
There used to be a citrus product product named Desolvit that worked real well.It was in grocery stores, not sure if it is still available but it's the best I've ever seen and it will not harm that decal or paint etc.
This guy has the same duct tape issue,, but, it is on his roof!!
The duct tape is shown at 3:49 minutes.
I wonder what he uses?? :D
:laughing:
   / How Do I Remove Aged/Dried Duct Tape? #20
The PB Blaster should work similar but WD-40 is great for removing adhesives.
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
JOHN DEERE 2750 TRACTOR (A54756)
JOHN DEERE 2750...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
