How do I remove injectors and spray nozels out
   / How do I remove injectors and spray nozels out #1
RisingStar
North Texas
JD 850 & 1435 & GS30
I'm trying to replace the cylinder head and trying to remove the old injector spray nozzles from the old head. Any suggestions? /forums/images/graemlins/confused.gif
   / How do I remove injectors and spray nozels out #2
RisingStar,
There is a current thread running under "Parts and Repairs" that addresses the exact same problem concerning stuck slide in or friction style injectors. All of the suggestions are very good and will apply to your problem.
Good luck and welcome to TBN, Mark
   / How do I remove injectors and spray nozels out #3
Need more info. What's holding them in, are they loose or tight? Is the head off the tractor?
   / How do I remove injectors and spray nozels out #4
Don't do like a guy I talked to last week did. He took the retaining nuts off and had a buddy turn the tractor over while he was going "tap on them a little". He had to order new chambers because after he got back from getting stitches on his forehead he couldnt find them.
Aaron
Parts@HoyeTractor.com
(940)438-0386
   / How do I remove injectors and spray nozels out #5
I had some stuck, that my machine shop had ruined trying to push them out with a press. I took the head home and started putting PB Blaster on them daily and tapping them with a brass hammer. I mean tapping. After a few days they popped out with a tap.
2013 Husqvarna YTH18542 42in Riding Mower (A51694)
2013 Husqvarna...
Unused 2025 Spirit Mini Golf Cart (A51694)
Unused 2025 Spirit...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
New/Unused Forklift Jib (A51573)
New/Unused...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2007 National RV Dolphin 35FT Class A Motorhome (A51694)
2007 National RV...
