How do I smooth my pastures
   / How do I smooth my pastures #31
Not sure if you have come up with a solution to smoothing out the pastures, but I had a similiar situation on my farm in central Virginia after logging. Try a Harley Rake. It's got to be one of the most amazing implements for smoothing ground. It also leaves a wonderful seed bed so you can plant right away without any other ground prep. Everything Attachments has a video of one working. I rented mine from my farm supplier. They're pretty pricey to purchase.
   / How do I smooth my pastures #32
I'm not sure if I'm posting this in the right place. I have 2, 5 acre pastures with hay growing in them. They are completely open but somewhat bumpy. I'm in central Florida so my soil is very sandy. Could someone point me in the right direction with how I can smooth these pastures out? I just cut them back for the winter and I really need to try to get them a little smoother. All advice is appreciated.
You need to drag an attachment with gauge wheels. Pull a landscape rake or scraping blade (or both as per Landpride) with gauge wheels attached - limit initial depth to about an inch with the wheels. Run the area over in two directions and it should be flat.
JayC
   / How do I smooth my pastures #33
I have the same issue. We bought 6 acres of land surrounding our current property. It's fairly rocky in some of the lower spots (grapefruit sized rocks or larger), and I've hauled out many buckets full. Anyway, I didn't do anything with it right away and weeds took over, so I just ended up mowing it. It's so bad that I swear I'm 2 inches shorter when I'm done with it.
I talked with a local farmer and we kicked around a plan of him plowing and disking it, and planting it in alfalfa. In exchange, I let him take the alfalfa for however many years it takes to pay off the seed and his work.
The good part is, I wouldn't have to mow the land (except for a small camp site we plan to make), and I wouldn't have to pay for seed and working the land. The bad part is, he said a ballpark estimate for him to get his money back would be 5 years...which means I couldn't do anything else with the land until he's done with it (or pay him off before the end of the 5 years).
I'm thinking of doing it myself now that I read this. Maybe I could find a used disc harrow and chain harrow somewhere. Seed is expensive but I already have a broadcast seeder just sitting here (used once and paid 100 for it, couldn't pass it up even if I wasn't going to use it right away). My only fear is not being able to water that much land, and wasting a lot of $$ in seed if things don't pan out. My wife knows somebody who will give us 2 or 3 baby miniature horses and I think that would be cool (plus I would get to build them a little barn). I don't know, I don't mind the work but I'm undecided yet.
What would you do...have the farmer do it or try to do it yourself?
   / How do I smooth my pastures #34
A Harley Rake is the best way to go but they are even expensive to rent. A rear roto tiller will grind up the high spots and then a box blade will redistribute the soil.
   / How do I smooth my pastures #35
I have the same problem with rough terrain in my back yard which is about 4 acres. Mine has a sunken ditch where we put in a water line that runs the entire length and that will require some fill dirt which I have plenty of from the pond dig out. I think the rest is from cattle tracks when we used to let the cows graze the area and maybe some hidden rocks, whatever it is a killer to travel across at anything above snail pace.I am going to try back dragging with my FEL and rake it with my Landscape rake. If that doesnt work, I will disc the whole thing up and use my 8 foot rake to smooth it out and then reseed. That wont be till next spring. I will try to post some results. Discing, raking, harrow, back dragging, grading all might be required to smooth out rough areas.
   / How do I smooth my pastures #36
Your other option is to plow and disk the field and then reseed it
The University of Maine - Cooperative Extension Publications - Bulletin #2491
   / How do I smooth my pastures #37
For smoothing pastures with mounds and dips I use a heavy landplane/grader with straight blades. It will fill with grass but I ignore it and keep going. You can get better results if you disk or till first but the landplane/grader will cut off the mounds quickly in sandy soil.
Old pics of my 8' landplane/grader
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
7022 (A50322)
7022 (A50322)
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2021 JCB 1CXT Skidloader/Backhoe (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 JCB 1CXT...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
