How do I vent a 55 Gallon Drum?
   / How do I vent a 55 Gallon Drum? #1
Reddcow
IL
None
I am new and don't know the best place to put this.
How can I vent a 55 gallon drum with water in it? It is a closed top drum with two bungs. Thanks.
-John.
   / How do I vent a 55 Gallon Drum? #4
Need a drain hole ?, I got an idea for that.
   / How do I vent a 55 Gallon Drum? #5
OK, Lets be a little more specific. EXACTLY, what kind of vent you thinking about?
I'm not sure what type of vent, just a vent for the air, so the drum doesn't collapse in on itself. I can't remove one of the bungs because the drum will be on its side. So water would pour through the other bung if I did that.
   / How do I vent a 55 Gallon Drum? #8
It's a simple solution. Screw a 3/4 street elbow into the upper hole. Extend with a short length of pipe ( 3 inches)over the drum. If the 2" hole is on top, you'll have to use a reducing bushing/s
   / How do I vent a 55 Gallon Drum? #9
Seen alot of bung hole caps with a 3/4 tapped pipe hole.
   / How do I vent a 55 Gallon Drum? #10
we use drums of concentrated coolant at work and just put a ball valve into the 3/4 hole, tip up on the stand and just crack the 2 in bung a little so it will suck air when the internal vacuum rises. once the level gets down it's easy to crack it some more. the valve allows easy filling of small pails to dump into the machines.
2006 Magnum 125 125kW T/A Towable Diesel Generator (A53421)
2006 Magnum 125...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A56129)
2007 TEREX ADVANCE...
Pallet of Car Parts (A47477)
Pallet of Car...
2017 Kia Sorento SUV (A53424)
2017 Kia Sorento...
UNUSED Folding 4-Step Stool Ladder (A53117)
UNUSED Folding...
